Senseless1 Posted April 3, 2020 Share Posted April 3, 2020 I have a 3.90 JDM 99 legacy 5mt and a USDM 08 3.9 5mt that may or may not have a working center diff. I'm using the 08 rear diff, which I'm reading is lsd. It would be nice to have a center lsd as well. I only need it to hold 350 whp for now. Does anyone know if I can swap them out and put the 08 center diff in the 99 case? Link to comment Share on other sites More sharing options...
rhino6303 Posted April 3, 2020 Share Posted April 3, 2020 What are the numbers for the transmissions? If the WRX is TY758VW1AA, it has a viscous center diff with part number 38913AA101. If the JDM Legacy is TY754VBAAA, it also has a viscous center diff with part number 38913AA101. This is according to the rallispec pdf. Link to comment Share on other sites More sharing options...
Senseless1 Posted April 3, 2020 Author Share Posted April 3, 2020 Ooh let me check if I still have it Link to comment Share on other sites More sharing options...
Senseless1 Posted April 3, 2020 Author Share Posted April 3, 2020 What are the numbers for the transmissions? If the WRX is TY758VW1AA, it has a viscous center diff with part number 38913AA101. If the JDM Legacy is TY754VBAAA, it also has a viscous center diff with part number 38913AA101. This is according to the rallispec pdf. Per that chart all the diffs I have are open so scratch that. Also I was sold a "jdm wrx turbo 5 speed transmission" Per that chart and the search I did last time using the actual number I must actually have a JDM NA legacy 5 speed. I sure as hell paid wrx pricing. Make sure you double check the numbers on the actual unit when you're at the JDM importer... Link to comment Share on other sites More sharing options...
rhino6303 Posted April 4, 2020 Share Posted April 4, 2020 Will you post your transmission numbers for thread posterity? Thanks. Link to comment Share on other sites More sharing options...
Senseless1 Posted April 5, 2020 Author Share Posted April 5, 2020 Where are the numbers again? Where do I have to be to see them with the transmission still in the car? Link to comment Share on other sites More sharing options...
rhino6303 Posted April 5, 2020 Share Posted April 5, 2020 Where are the numbers again? Where do I have to be to see them with the transmission still in the car?It should be on the bell housing where the starter bolts through the transmission. Link to comment Share on other sites More sharing options...
