Northern1 Posted March 10, 2020 Share Posted March 10, 2020 I believe water is seeping into my trunk via the spoiler as whenever it rains the underside of the trunk lid is wet and I'm not currently seeing any other way the water can be there. So I gotta seal that up but in the meantime I noticed the carpet and board covering the spare wheel is moldy as hell. The board covering the spare is I think some kinda inexpensive fiberboard which I figured I could probably fashion easily by using the existing one as a template. Has anyone done this? What material is exactly the cover board? Also where besides the dealer can I possibly get the carpet replaced? I live in Canada. I considered cleaning the carpet but not sure if it's salvageable or cleanable without destroying it. Link to comment Share on other sites More sharing options...
choover1101 Posted March 11, 2020 Share Posted March 11, 2020 (edited) I have been using a piece of 1/4" clear hard plastic over the tire well for years. Sold as a hard bathroom floor mat. Only down side is stuff slides around back there. I pulled all carpet and bedlinered due to water damage when I got my 96GT. (I had to pull the plastic out as my new full size spare does not fit completely in the wheel well. 235/60-16) I missed the part about replacing the carpet, LMC, Jegs, Summit Racing, or maybe a local carpet store might be a source for some carpet. I would use headliner spray adhesive to glue it down to whatever material you decide to make the new one out of. Also, keep a small scrap of the original carpet to match as best you can. Sent from my SM-N950U1 using Tapatalk Edited March 11, 2020 by choover1101 Link to comment Share on other sites More sharing options...
Northern1 Posted March 11, 2020 Author Share Posted March 11, 2020 Thanks for the reply. I think I might just use a piece of plywood. As for the carpet I see that it's some kinda foam mat and then there's the grey cover. Trying to figure how much I can possibly salvage but I'm thinking to just buy a replacement carpet if it's not crazy expensive. Link to comment Share on other sites More sharing options...
doublechaz Posted March 11, 2020 Share Posted March 11, 2020 Best to paint the wood to make it stand up to abuse longer. Link to comment Share on other sites More sharing options...
Das Ninjabot Posted March 11, 2020 Share Posted March 11, 2020 I had to replace mine as well, but went to a salvage yard and got a new board, carpet, and 3rd gen tool kit and foam insert for $20. Link to comment Share on other sites More sharing options...
RyanShort Posted May 2, 2021 Share Posted May 2, 2021 (edited) I had the same situation a couple of days ago... What did you decide to do in the end? My entire trunk is completely flooded with water. My children did it, but I try not to be angry with them because I was also a little prankster who often broke something in childhood. In general, I think to contact the floor restoration specialists. They already helped us once when we were flooded by neighbors who live on the floor above us. I hope they do similar work too. In any case, I will be very grateful for your advice and suggestions on cleaning. Thank you in advance! Edited May 7, 2021 by RyanShort Link to comment Share on other sites More sharing options...
Northern1 Posted May 3, 2021 Author Share Posted May 3, 2021 Carpet I cleaned and let it dry out in the sun. As for the spare wheel cover I bought some kinda corrugated plastic and cit it to fit. Link to comment Share on other sites More sharing options...
