Subaru dreams Posted March 8, 2020 Share Posted March 8, 2020 My throw out bearing went when i was in 2nd gear. Pulled trans (6mt, VIN:TY756wlaaa) replaced TOB, and clutch. I had limited space and was on the ground so i left cables hooked up and made sure not to put any pressure on them but i im 97% they moved from where they were b4 removing. I dont know if that makes any difference at all either. But after everything was put back together i noticed the shifter was still stuck in second so i was able to get it out with little force. I can engage all other gears while car is running when engaging the clutch. But there is nothing happening in the 1 and 2 gate no need for clutch to move the shifter to either one, it goes right into both like nothing is there clutch or no clutch. And sometimes when my stick is in neutral it is actually in a gear cant tell which tho. With a little finicking around i can get it out and back into neutral.. Please help!! I havent found anything thus far. Thank you! Link to comment Share on other sites More sharing options...
