Max Capacity Posted January 7, 2021 Share Posted January 7, 2021 4 post instead of a 2 post...is there another thread for that topic ? Here's a site I've been looking at recently. You can see links to different lifts there. https://www.gregsmithequipment.com/Atlas-9KOHX 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
theflystyle Posted January 7, 2021 Author Share Posted January 7, 2021 4 post instead of a 2 post...is there another thread for that topic ? Here's a site I've been looking at recently. You can see links to different lifts there. https://www.gregsmithequipment.com/Atlas-9KOHX I might do a separate thread if it comes closer to fruition. I gotta get the 4-post to keep the SVX up in the air during the "bad" weather and then I can park the Legacy underneath. Storing cars on 2-posts is not ideal and they require thicker concrete to be installed (bolted) while the 4-post does not require the same thickness/PSI or being bolted down. Link to comment Share on other sites More sharing options...
Max Capacity Posted January 8, 2021 Share Posted January 8, 2021 You only need the 6" floor in the general area of the post. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
