LGTodd Posted February 4, 2020 Share Posted February 4, 2020 BL/BP Brembo swap: Here is a general breakdown of what is needed to swap GD chassis 04-07 Brembos to the 4th gen Legacy BL/BP for all of the new members who might be interested. 08+ STI front calipers will bolt up but the rear calipers will not as there is no bracket made for them yet. You could have one machined if you have the resources and knowledge. Front: OEM 04+ STI Brembo caliper 04 STI 5x100 Rotor 04+ STI brake pads (unless running the 2018 6 pot fronts which will obviously require 2018+ 6 pot pads) Rear: OEM 04-07 STI Brembo Caliper 04-07 STI brake pads (08+ could work? Not sure on sizing and have not confirmed fitment/part numbers myself. There are a couple options as far as fitting the rears and making them work. First, you will need the brackets to adapt the caliper to the LGT knuckle such as Kartboy, Torque Solution, and so on. Second, you will need to decide whether you want to use the upgraded parking brake or not. If not you are limited to what rotors you can get. If you decide to run the thicker ebrake shoes (KNSbrakes.com sells them) then you will be able to use the 04 STI 5x100 rear rotor of your choosing. If you decide NOT to use the thicker ebrake shoes you will need to run rotors that are typically labeled (WRX rear Brembo upgrade) as these will work with the stock legacy ebrake shoes and are 5x100. DBA makes a T2 and T3 4000 series option for this and the part numbers are DBA-2657 for the T2 rotors and DBA-42657S for the T3 4000 series rotors. *ALTERNATIVE OPTIONS* Powerstop does sell remanufactured 04-17 front Brembo calipers. They are part number S3698 (they will show two different style calipers on most sites but they are confirmed to be the remanufactured Brembos by Powerstop and myself as I purchased them. They will be doing remanufactured rear 04-07 calipers as well, in their words “Not currently, but soon” Please feel free to add any info and I can edit if needed. 2 Link to comment Share on other sites More sharing options...
