06SubLegTx Posted January 3, 2020 Share Posted January 3, 2020 Hello, A few days ago I heard my ac blower motor making just a little noise. Today the blower motor would not do anything on any setting. I can hear the ac compressor click on/off when I main press the switch, but NO moving air on any setting. My car have the all in one unit. (Radio & AC/Climate Control Panel all in one) The car has 151k on it Any help would be appreciated. Link to comment Share on other sites More sharing options...
06RENN Posted January 10, 2020 Share Posted January 10, 2020 (edited) It's possible it's a fuse. On my older Acura I would hear the blower motor at anything higher than the lowest setting so the noise symptom my not mean much. Or, it could mean it was about to fail. If you can locate the blower motor and the terminals you can bypass the HVAC control and supply Pos and Neg directly from the battery to see if it runs. It will operate on the same 12v as everything else. Good luck. Edited January 10, 2020 by 06RENN Link to comment Share on other sites More sharing options...
