frank_ster Posted December 25, 2019 Share Posted December 25, 2019 Let me know if there is already a thread like this. But I couldn’t find Anyways my o5 wagon I changed clutch and the tob chirped forever , Now I have 09 outback , I get a clutch kit. And the throw out bearing is slightly loose , it’s 33.6 mm Id. The original is about 33.1. The shaft is 33mm Also looking at the tob the outer spinning part not concentric with the inner sliding sleeve . What’s the deal eh ? Just shitty parts ? Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
Max Capacity Posted December 27, 2019 Share Posted December 27, 2019 I'm thinking crappy parts. Just put a little high temp grease on the tranny snout for the TOB to slide on. I dab in the Pilot bearing is a good idea too. I also lightly grease the splines too. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Nonamedude Posted December 31, 2019 Share Posted December 31, 2019 Yea sounds like just differences in manufacturing tolerances. Considering that you can use the tsk kit to sleeve the snout and run a larger bearing without issue. I didn't measure mine before putting it on but that's only 1.5% difference in size. Is your snout still nice and smooth? Maybe swap it. I'm assuming it's oe? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
