awfulwaffle Posted December 23, 2019 Share Posted December 23, 2019 Like the title says - after a front LSD for a 5MT, before I spring for a new one. Let me know what you have! Link to comment Share on other sites More sharing options...
awfulwaffle Posted January 10, 2020 Author Share Posted January 10, 2020 Bumpy, I guess Link to comment Share on other sites More sharing options...
alupo0 Posted January 20, 2020 Share Posted January 20, 2020 I know your looking for just the LSD but I have a low mileage 5MT in really good shape if that may be of interest to you. Link to comment Share on other sites More sharing options...
whitetiger Posted January 20, 2020 Share Posted January 20, 2020 All USDM 5MTs came with Open Diffs. Any front LSD that fits the 5mt will be JDM or aftermarket. Bet bet, OP, is to just import one, or buy from a reputable gearbox shop like rallispec.com Link to comment Share on other sites More sharing options...
awfulwaffle Posted January 20, 2020 Author Share Posted January 20, 2020 All USDM 5MTs came with Open Diffs. Any front LSD that fits the 5mt will be JDM or aftermarket. Bet bet, OP, is to just import one, or buy from a reputable gearbox shop like rallispec.com Yeah I came to that conclusion, but figured it was worth checking. There does appear to be one of the front LSD 5mts currently available from an importer... Link to comment Share on other sites More sharing options...
awfulwaffle Posted January 20, 2020 Author Share Posted January 20, 2020 I know your looking for just the LSD but I have a low mileage 5MT in really good shape if that may be of interest to you. Appreciate the offer, but was looking for just a diff. Have a few 5MT cases/gearsets sitting already Link to comment Share on other sites More sharing options...
alupo0 Posted January 20, 2020 Share Posted January 20, 2020 Appreciate the offer, but was looking for just a diff. Have a few 5MT cases/gearsets sitting already No worries, just thought I'd ask Link to comment Share on other sites More sharing options...
whitetiger Posted January 20, 2020 Share Posted January 20, 2020 Yeah I came to that conclusion, but figured it was worth checking. There does appear to be one of the front LSD 5mts currently available from an importer... make sure the FD on that box matches the rear diff you plan to use with it. IIRC, most of the 5mts that had a FLSD in them were 4.44, but the USDM 5mt is a 4.11 for the 05-06 model. When i did my FLSD upgrade a while back, i bought new from rallispec and had it installed when my 5mt was being rebuilt. Link to comment Share on other sites More sharing options...
boxkita Posted January 20, 2020 Share Posted January 20, 2020 make sure the FD on that box matches the rear diff you plan to use with it. IIRC, most of the 5mts that had a FLSD in them were 4.44, but the USDM 5mt is a 4.11 for the 05-06 model. When i did my FLSD upgrade a while back, i bought new from rallispec and had it installed when my 5mt was being rebuilt. rebuilding a 5mt instead of upgrading to 6mt? curious why? Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
awfulwaffle Posted January 20, 2020 Author Share Posted January 20, 2020 make sure the FD on that box matches the rear diff you plan to use with it. IIRC, most of the 5mts that had a FLSD in them were 4.44, but the USDM 5mt is a 4.11 for the 05-06 model. When i did my FLSD upgrade a while back, i bought new from rallispec and had it installed when my 5mt was being rebuilt. So the understanding I had was that the ring gears are interchangeable, which assumes the pinion is cut the same between the 4.444 and 4.111. Never verified this, though. Do you have any evidence whether or not that's the case? That said, the box I found is one of the two 4.111 units that came in the 01-03 JDM LGT. Link to comment Share on other sites More sharing options...
whitetiger Posted January 20, 2020 Share Posted January 20, 2020 (edited) no. the 4.11 ring and pinion are usually a matched set. you can't use a 4.44 ring and a 4.11 pinion or vice versa. ok, that box should work. make sure it takes make axles. older suby 5mts had stubby axles sticking out of the trans. Edited January 20, 2020 by whitetiger Link to comment Share on other sites More sharing options...
awfulwaffle Posted January 20, 2020 Author Share Posted January 20, 2020 Dumb brain meant swap 4.111 ring onto LSD and use with USDM 4.111 pinion Link to comment Share on other sites More sharing options...
whitetiger Posted January 20, 2020 Share Posted January 20, 2020 yes, that's the way to do it. Link to comment Share on other sites More sharing options...
