mckman Posted November 19, 2005 Share Posted November 19, 2005 I don't work for Renick, but I thought this was page had enough worthwhile info. to post. The link below has a bunch of great pictures of the Spec B suspension and also gives the complete parts list with both prices and part numbers. Renick Motorsports is selling the Strut and Spring Kit for $1,610 and the Aluminum Arms (front and back) for $1,394. That's about $3k for the complete setup. Pricey indeed, but not that bad considering your are changing almost everything in the suspension except the swaybars. http://www.renickmotorsports.com/oscommerce/catalog/product_info.php?cPath=254_354_745&products_id=1531 Here is the text from their website. This Bilstein Suspension comes standard on the 2006 Legacy Spec B. Convert your standard Legacy GT sedan with these tuned suspension components. Chose either the Strut and Spring Kit, Aluminum Arm kit or both to drastically improve the handling of your Legacy. Each kit comes with new components listed below. Parts listed replace or work with existing suspension components. All parts are brand new factory parts. Strut and Spring Kit 20310AG400 - Front RH Strut $436.59. 20310AG410 - Front LH Strut $436.59. 20320AG000 - Front Strut Mount $60.23 each (2). 20322AG010 - Front Strut Dust Cover $10.03 each (2). 20323AG000 - Front Spring Seat $12.38 each (2). 20330AG720 - Front Coil Spring $68.63 each (2). 20365AG260 - Rear Shock Absorber $289.35 each (2). 20370AE000 - Rear Strut Mount $33.50 each (2). 20372AE000 - Rear Shock Dust Cover $8.40 each (2). 20375AE000 - Rear Rubber Spring Seat $13.37 each (2). 20380AG540 - Rear Coil Spring $68.63 each (2). This Strut and Spring Kit retails for $2002.22 and we are offering at a discounted price. $1610.83 Special price. Chose this or both kits from the pull down menu. Aluminum Arm Kit 20202AG160 - Front RH Control Arm $370.43. 20202AG170 - Front LH Control Arm $370.43. 20252AG021 - Rear RH Trailing Arm $357.20. 20252AG031 - Rear LH Trailing Arm $357.20. 20250AG000 - Rear Forward Lateral Link $58.60 each(2). 20250AG030 - Rear RH Upper Lateral Link $83.70. 20250AG040 - Rear LH Upper Lateral Link $83.70. This Aluminum Arm Kit retails for $1739.86 and we are offering at at a discounted price. $1394.20 Special price. Link to comment Share on other sites More sharing options...
ebpda9 Posted November 19, 2005 Share Posted November 19, 2005 that's a load of money. i am sure a bilstein strut kit will show up for a lot cheaper in the near future. Link to comment Share on other sites More sharing options...
mckman Posted November 19, 2005 Author Share Posted November 19, 2005 I agree the parts are pricey, but that's what you get buying from the dealer. The Bilstein B6 Sport shocks are available on the European site, but there is no pricing yet. When they become available in the U.S. they will likely be much cheaper. http://katalog.bilstein.de/ Not much alternative to the dealer for the suspension arms themselves. The WRX aluminum front control arms are less than half the price of the very similar Legacy ones, bummer. They should be lighter and come with stiffer bushings that should increase the responsiveness of the handling. However, I don't know if it is really worth it given the price. Would be great to find out the weight difference between the steel and aluminum parts. In any case, those were the most detailed pictures I have seen of the Spec B suspension, which others might find interesting. Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted November 19, 2005 Share Posted November 19, 2005 Wow- 480 per strut? Speculum B owners are gonna love it when it's time to replace them :shake: Link to comment Share on other sites More sharing options...
subysouth Posted November 19, 2005 Share Posted November 19, 2005 There will be less expensive options by the time they will need replacing. Probably not as good but less expensive. You can also have the struts rebuilt by Bilstein for about $60/strut plus hipping both ways to SoCal. ss Link to comment Share on other sites More sharing options...
subysouth Posted November 19, 2005 Share Posted November 19, 2005 And mckman thanks a lot for all the PNs and prices. Those are very helpful bits of info. ss Link to comment Share on other sites More sharing options...
ebpda9 Posted November 19, 2005 Share Posted November 19, 2005 They should be lighter and come with stiffer bushings that should increase the responsiveness of the handling. However, I don't know if it is really worth it given the price. Would be great to find out the weight difference between the steel and aluminum parts. In any case, those were the most detailed pictures I have seen of the Spec B suspension, which others might find interesting. i am assuming a 10lbs difference on each control arm, which does not do a lot for the weight savings on the car, but 10lbs of unsprung weight does a lot for suspension. Link to comment Share on other sites More sharing options...
urbanachiever Posted November 19, 2005 Share Posted November 19, 2005 the million dollar question, is will this setup fit a wagon? Link to comment Share on other sites More sharing options...
subysouth Posted November 19, 2005 Share Posted November 19, 2005 the million dollar question, is will this setup fit a wagon? Everything should work except the rear springs. If you need a wagon Bilstein setup, I have one for sale in the classifieds. ss Link to comment Share on other sites More sharing options...
rfd425 Posted November 20, 2005 Share Posted November 20, 2005 i am assuming a 10lbs difference on each control arm, which does not do a lot for the weight savings on the car, but 10lbs of unsprung weight does a lot for suspension. Really? That seems high to me, but if it's really 10 pounds per corner, that's pretty significant. Also, would the whole 10 pounds really be unsprung? I would think of it as partially sprung. Now, what I really want to know is which STi Pink springs are the best match for the USDM Bilsteins. Link to comment Share on other sites More sharing options...
chucktoo Posted November 20, 2005 Share Posted November 20, 2005 The two million dollar question is will the arms fit an Outback XT ? I priced the al suspension pieces on Subaroparts.com and got $1416 plus $170 in shipping. Link to comment Share on other sites More sharing options...
Th3Franz Posted March 28, 2006 Share Posted March 28, 2006 Have these prices changed at all? -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
