05 lgt 5spd
**I got some exhaust leak, not sure were to start now that I saw one nut on the left side of the turbo was loose as s**t. I tightened it back down, but still hearing something on that side. Should I buy new uppipe gasket? Could it be slight tap/knock?? While I had the TMIC, went ahead and regreased my starter shout out to "chato" very informative post!20191130_120801.thumb.jpg.31163fb89b5b60200aeb8291d4e2ff31.jpg
Sent from my SM-G960U using Tapatalk
If the car is a 05-06 you should make sure it has a catless up pipe too.
If your going to replace the up pipe, replace the oil return hose too.
make sure you remove the banjo filter on the back of the passenger side head too.
FWIW, I bolt the turbo to the up pipe.
Engine Build - Click Here
  • 3 weeks later...
[ATTACH]281148[/ATTACH]
[ATTACH]281149[/ATTACH]
What's FWIW, #noob
But yes it 05 lgt limited I believe. Not sure if it has catted UP, I'm planning on new shifter linkage (OEM Subaru) its sloppy side movement. Hows that banjo filter look like?
What's FWIW, #noob
Here's a link to see where they are located.
https://forums.nasioc.com/forums/showthread.php?t=2834394
