06ShagWagonGT Posted November 21, 2019 Share Posted November 21, 2019 (edited) Noticed the other day at a red light that there was a small amount of steam coming up from the right side of the hood. Noticed a slight burning smell I’m thinking some kind of coolant or turbo leak but I’m not sure. Car doesn’t overheat or leak anything onto the ground. I just notice a slight burning smell from the passenger side of the engine when it gets up to temp, very small amount of steam. Any ideas??? Edited November 21, 2019 by 06ShagWagonGT Link to comment Share on other sites More sharing options...
Max Capacity Posted November 21, 2019 Share Posted November 21, 2019 There's a few possibilities in that area. You'll need a good light, get under the car and look up in that area. You may be able to see something from up top too. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Berge56 Posted November 21, 2019 Share Posted November 21, 2019 Could be your A/C drain.... Did you recently install a Downpipe on the car? Link to comment Share on other sites More sharing options...
Nonamedude Posted November 21, 2019 Share Posted November 21, 2019 Yea I can see back there real well from underneath and you can see the oil return and coolant return from the turbo, oil return was where my issue was. Without having more info, it could also be the oil feed lines from the head to avcs and turbo. They crack sometimes with repeated turbo removal. I think on the 06 from the head is on the back of the head so you should be able to see that. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 21, 2019 Share Posted November 21, 2019 If you click on the link in my sig, you'll find lot's of pictures that show that area on the engine. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
06ShagWagonGT Posted November 23, 2019 Author Share Posted November 23, 2019 I will be taking a deeper look tomorrow and that will definitely help me out thank you! Link to comment Share on other sites More sharing options...
dwmccauley01 Posted November 23, 2019 Share Posted November 23, 2019 When my oil line on the turbo was leaking it smelled like plastic. If that rubber coolant return hose with the metal protection on has slid off the hard line a bit it will leak quite a bit also. Sent from my VS501 using Tapatalk Link to comment Share on other sites More sharing options...
