KRM Posted October 31, 2019 Share Posted October 31, 2019 I've searched for this before anyone says to do so. Besides the usual "trim the radiator hoses" solution, my issue is different. It seems that the radiator is just a little bit taller? It's sits higher than the oem and I'm using the original lower bushings by at least a half inch. All things considered I'm going to use a thin rubber material in its place to bring it down. Too late to turn back and my oem radiator is now a target in the back yard lol.... Anybody else have this happen? Everywhere I looked this is a direct fit part, and all photo images I see it sits flush. If not, at least it will come up in a search for anyone else who is going this route to be aware of. Link to comment Share on other sites More sharing options...
Infosecdad Posted October 31, 2019 Share Posted October 31, 2019 Which part number did you get? Link to comment Share on other sites More sharing options...
Notorious Posted October 31, 2019 Share Posted October 31, 2019 Are you sure the radiator is sitting properly and the pegs are in the holes? I went with Koyorad because Mishimoto build quality isn’t on par. Link to comment Share on other sites More sharing options...
KRM Posted October 31, 2019 Author Share Posted October 31, 2019 Yeah its seated in the bushings all the way. Mmradsti08. I purchased this one because every review was the same as others at the time. It's been in the garage for the last few years waiting for me to install.... I'll just cut the bushings or like I mentioned put some rubber padding in their place. Link to comment Share on other sites More sharing options...
Infosecdad Posted October 31, 2019 Share Posted October 31, 2019 I have the same one. What part isn’t sitting flush? For mine, the left side that’s under the intake is flush, but the right side with the inlet and cap sits higher above the front. I can post a pic when I get home tonight if that might help. Link to comment Share on other sites More sharing options...
KRM Posted October 31, 2019 Author Share Posted October 31, 2019 With the lower bushings in the whole thing is about a half inch too high for the upper mounts to even touch the bolting points. Go figure. Link to comment Share on other sites More sharing options...
