2charlie Posted October 18, 2019 Share Posted October 18, 2019 I just purchased a used 2018 Legacy 3.6r Limited. I read the manual but I was not clear on it yet. I've also watched some Youtube video but still I'm unable to set the seating. Here's what I did. Adjust the seat the way I wanted.Turn the engine offPress the set and the 1 butt at the same time I did not hear any beep indicating that was set. What do I need to do? Once I have the seat setting registered, I also need to set the remote as well. Link to comment Share on other sites More sharing options...
silver_ice Posted October 19, 2019 Share Posted October 19, 2019 Adjust it and then press and hold the 1 or 2 button until you hear the chime - have to hold it for maybe 5 seconds or something like that...at least that's the way it is on my '19 3.6r Limited. Link to comment Share on other sites More sharing options...
tumbleweed 49 Posted October 19, 2019 Share Posted October 19, 2019 (edited) Transmission in P, push Set and hold it in while you push 1 or 2. It will beep when it is set. If you are registering it with the key FOB the procedure is a little more complex but the one listed in the owner's manual on pages 1-6 & 1-7 should work. Edited October 20, 2019 by tumbleweed 49 Link to comment Share on other sites More sharing options...
2charlie Posted October 19, 2019 Author Share Posted October 19, 2019 So, I should not press the set and 1 at the same time then. I should press set first then 1 or 2, correct? Link to comment Share on other sites More sharing options...
silver_ice Posted October 20, 2019 Share Posted October 20, 2019 I don't know - on my 2019 3.6r limited all I have to do is press the number and hold it - I don't even have a 'set' button. Link to comment Share on other sites More sharing options...
tumbleweed 49 Posted October 20, 2019 Share Posted October 20, 2019 (edited) So, I should not press the set and 1 at the same time then. I should press set first then 1 or 2, correct? Yes, what works for me is press and hold "Set" then press 1 or 2 and you will get the beep. Edited October 20, 2019 by tumbleweed 49 Link to comment Share on other sites More sharing options...
2charlie Posted October 20, 2019 Author Share Posted October 20, 2019 Awesome, thank you! I'll give that a try. Link to comment Share on other sites More sharing options...
hkshooter Posted October 21, 2019 Share Posted October 21, 2019 I seem to recall the parking brake must be set to do this. Sent from my SM-G950U using Tapatalk Link to comment Share on other sites More sharing options...
SubieN8 Posted October 21, 2019 Share Posted October 21, 2019 Nope. It’s easy. You can be driving and setting the memory function will still work. 1. Find your favorite seating position. 2. Press and hold the Set button first, then while it’s still pressed, press and hold the the 1 or 2 and you’ll hear the beep. You’re done. This works on my 2018. Link to comment Share on other sites More sharing options...
