Warlocks Daily: 08 LGT Spec B Engine Rebuild
Warlock
I will finish posting details as soon as I get a free minute at work.
Hello All, this is my 2008 Legacy GT Spec B. I bought it with a low compression motor back in December, it ran but I knew it wasnt long for this world. Luckly, I had quite a bit of spare parts laying around from building my drag car, a 2012 WRX. I had a 2005 LGT laying around that became the doner of several parts such as the heads (its the Red LGt in the photos below, it will also be getting built soon).
Heres the specs on the parts:
2004 Forester XT block honed 10 over
Manley Forged Pistons, stock compression
STi rods w/ ARP Rod bolts
King Race Bearings
Brand new STi Crank
Perrin lightweight pulley
2005 LGT heads
OEM Gasket set, oil pump, Gates racing Timing and water kit
ARP 2000 head studs
Brian Crower dual valve springs, valves. retainers, seats, keepers, ect
GSC bronze valve guides
Stock LGT intake manifold
Torque Solutions TGV deletes
Grimmspeed TGV spacers
Cobb intake (came with red car)
FP Red turbo, ported, with 10CM hot side, internally gated
FP inlet pipe (expensive!)
ID1000 injectors
Perrin fuel rails
Aeromotive Fuel Pressure Regulator
Grimmspeed EBCS
Stock exhaust manifold and up-pipe from 2008 LGT motor
Generic catless downpipe 3"
Stock catback, nice and quiet :)
ETS black Intercooler piping
ETS 3.5" intercooler, anodized black
GFB electronic blowoff valve
Mishimoto Radiator, slim fans, and rad hoses
ACT Heavy Duty 6-Puck Disc Clutch Kit
New OEM power steering pump & AC Compressor
Generic catch can
Braided turbo oil and AVCS lines
DW300C Fuel pump
Mods:
Complete PCV system delete, all routed to catch can
Air pump removed due to 2005 heads
Intake air box delete to make room for intercooler pipes
custom ran fuel lines
Sti turbo side pieces to match an sti style turbo to an LGT intake manifold - THANK YOU ETS!!!!!!!
Software:
Open source via Tactrix
-15psi on intelligent with smooth throttle
-23psi sport with normal throttle (still tuning this area)
-29psi on Sport sharp with very aggressive throttle (still tuning this area)
-tinywrx flat foot shift / launch control patch
Visual:
Redline tuning hood rods
18X8.5 ENKEI TUNING TX5 PLAT GREY wheels with Nitto NT05 97W Tires 245/40/R18 for summer use
Raceland Coilovers
Drilled and slotted rotors
Edited by Warlock
update info
  • 3 months later...
  • 5 months later...
  • 2 months later...
So just as an update, I ran into several issues with this build. First, i installed the cam caps wrong and tightened them too much, constantly had timing over advanced errors AND oil leaking into timing case. After fixing that issue and doing timing all over again, my timing tensioner bolt snapped and I hopped timing while driving on the highway..... AMAZINGLY NO DAMAGE!! So, new timing belt kit and shes back up and running...... and after about 3500 miles or so, the brand new oil pump seized while I was on the highway and very quickly spun a bearing.... ugh, oh well, cant cry over spilled milk.
So, it sat for about 3 months and them I got back at it. Wanted to save time and just went out and bought an IAG closed dock short block and got about to doing some other upgrades while I was in there.
I got the IAG oil pickup and windage tray addon along with a killer b oil pan. I feel better knowing the pan is better baffled and has more capacity than stock. Brand new ARP stud kit. New clutch kit while I was at it too. IAG unequal length headers heat wrapped. Added a Perrin oil cooler into the mix as well (I plan to start road coursing the car next season, not so much drag racing). Got a Optima yellow top battery and relocated the battery to the trunk directly behind the rear seat. New slim radiator fan kit from mishimoto with hoses and such. I had an issue where the motor was rocking last time and occasionally the alternator would hit the upper radiator hose, so this time I did full torque solution mounts along with tranny mount. So we drop all this in, and we discover an oil leak from the rear main seal, my fault..... ugh, motor comes back out. Oil leak fixed, also found a coolant leak from the hose that goes to the throttle body so replaced that. Also got an RCM high grip timing tensioner this time, I dont want any more headaches at 8k rpm.
On the outside, i finally mounted my new wheels with Nitto NT05 tires (8.5 inch wide by 18 wheel) and dialed in the Raceland coilover kit. Got rid of the factory chrome front grill and replaced it with a JDM front grill (i always though calling something JDM was for street cred, but I actually waited like 4 weeks for this thing to clear customs from Japan.....so yeah, JDM?). My buddy was able to get the grill to mash up with a USDM bumper which was a headache.
So, anyway, I will try to get some pics up in the next few days.
Upcoming mods:
Grimmspeed master cylinder brace
Wilwood front brakes (ordered, waiting for delivery)
Whiteline full suspension kit (ordered, vendor says whiteline wont ship for a while...)
Oh, also forgot, running on wastegate pressure on the FP red, aka entire wastegate map is 0 with a max of 0, and I am just about maxing out my MAF sensor. So I can custom rigging up a 3.5" MAF housing and hopefully that will give me some room to start turning the turbo up. I really, really, really dont want to go speed density as I like to tune this myself on the street, not on a dyno.
Edited by Warlock
