(Roanoke, VA)- 2006 Subaru Legacy GT
Monkeybone
Year, Make and Model: 2006 Subaru Legacy GT
Color: OBP (Obsidian Black Pearl)
Miles: 113,702 daily driven so will go up
Transmission: automatic (5EAT)
Title: Yes
Lien: No
VIN: Removed due to car no longer up for dale
Seller's email address
Asking Price: $
Buyer backed out. I’ve decided to keep the car. Thanks.
The timing belt, tensioner, thermostat, idle pulleys, water pump, coolant, serpentine belt, ac belt, and spark plugs were changed at 102,204 (105k service). I have documentation for all maintenance since I've owned the car from 2010 and up. I'm not interested in parting out or trading as I already have another vehicle in mind. PM or reply if interested. Thank you.
Mod list:
Power/Engine:
Equal Length Header – Perrin
Uppipe (ceramic coated)- Grimmspeed
Downpipe (catted)- Cobb
Cat back- Borla
CAI intake (wrapped in heat reflective tape)- KN
FMIC (ceramic coated core and pipes- Racer X
Crank Pulley- Perrin
Turbo Blanket- DEI (I think)
Coolant Bypass Mod- Denton Motorsports
Bypass Valve- Forge
Fuel Pump- Deatschwerks
Transmission Cooler mounted in factory TMIC location- Denton Motorsports
Transmission Valve Body Mod- Hexmods
Battery relocated to trunk
Open Source ECU tuned
Suspension/Brakes
Front and Rear Endlinks- Kartboy
Front and Rear Swaybars- Cobb
Struts-Bilstein HD
Springs- H&R
Front Inner Control Arm Bushing- Whiteline
Front and Rear Pads- Hawk HPS
Stainless Steel Brake lines- Goodridge
Exterior:
JDM Side Spats
JDM Sports Grille
Hella Horns
35% tint (all around)
Interior:
Sti Pedals
All weather floor mats
Shift Boot- Zero Sports
LED interior lighting
Boost Gauge
JL audio speakers
Wheels/Tires- Car will come with either Black Enkei RPF 1's wrapped in Sumitomo HTRZ 235/40/17 (pictured) or 2006 OEM Legacy GT wheels powdercoated Glossy Black wrapped in General Altimax Artic 215/45/17. Depending on negotiation with buyer.
The bad:
The car is 14 years old, so it’s not perfect. There is wear and tear damage on the interior as well as exterior. The rear bumper has been replaced and some exterior parts have been repainted.
The glovebox latch is broken, I rigged a bolt to keep it closed. The airbag light randomly comes on, I had a tech look at it and they couldn’t find the issue.
Edited by Monkeybone
Not for sale
