Kkikinern Posted September 27, 2019 Share Posted September 27, 2019 (edited) So I hear that the stocker can be filled up with distilled water. Is this true? When you unscrew one of the 6 plugs, there is about a 1/2 slit in the plug. Do you put enough water in there to fill the little slit? What stock battery is good? The price no matter I played online poker and won, after choosing good casino on this page https://canadiancasinos-online.com/online-poker.php , so who can give me useful advice? Thanks Edited November 3, 2020 by Kkikinern Link to comment Share on other sites More sharing options...
DrD123 Posted October 3, 2019 Share Posted October 3, 2019 you can indeed top off the cells in the battery - you want to fill them to the full line (usually on the side of the case - i don't recall if it was on my OEM battery) - if you pull the vent covers, you generally want to fill just until the electrolyte level touches the plastic part that extends down from the hole you are filling into (the part with the slit in it you are referring to - the entire slit should be above the fluid level) - you absolutely do not want to fill them all the way to the top or your battery will leak electrolyte out of the vents at the top. Once the electrolyte covers the plates in each cell, there really isn't a benefit to filling it much higher than that. You are correct you want to use distilled water. Link to comment Share on other sites More sharing options...
