GearJamr Posted September 27, 2019 Share Posted September 27, 2019 i put some Sylvania H7 LED low beam headlights in my 05 GT last night. They work fine except when running just on DRL they flicker. If I turn on the headlights they are solid. My guess is the voltage or amps are just slightly lower for the DRLs and causing the flicker. Are there any solutions for this issue? Link to comment Share on other sites More sharing options...
fedaykin Posted October 1, 2019 Share Posted October 1, 2019 DRL usually runs at half voltage, hence the flicker. You can either disable DRL, or go back to halogen. Link to comment Share on other sites More sharing options...
Homedepotmade Posted October 9, 2019 Share Posted October 9, 2019 I just disabled my DRL yesterday on my 08 and this solved my problem right away. Took me 10 min. The DRL module is under the driver side dashboard at the firewall, next to the clutch pedal if you are manual. The module will have DRL on it so you can't miss it. Unplug the white connector and cut or unpin the blue with black strip wire. 2006 and below I believe you just need to unplug the white connector. Search on this if you fall under this category. Link to comment Share on other sites More sharing options...
