Andy_Mac Posted September 23, 2019 Share Posted September 23, 2019 Have any of you used something like this before? Can't find a heap of info on them and can't quite work out how they seal against the centre stud. They have O-rings on the outer edges of the insulators but don't mention anything firmly pressing them to the stud. https://www.efihardware.com/products/1593/submersible-pump-bulk-head-terminals 2000 Legacy B4 RSK - SOLD 2006 Legacy BP5 GT Spec B wagon - Garage Thread 2011 VW T5 van 2.0L of turbo diesel awesomeness Link to comment Share on other sites More sharing options...
Max Capacity Posted September 25, 2019 Share Posted September 25, 2019 You night get more responses if you put this in the 4th Gen forum. sounds like it should work. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Code Posted September 25, 2019 Share Posted September 25, 2019 Looks a bit more robust than the piece that iWire supplied me. Theirs is a plastic thingy that I had to fill with epoxy after the wires were passed through. For the record, I have had no problems with the plastic piece that I used. "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
Andy_Mac Posted September 28, 2019 Author Share Posted September 28, 2019 (edited) After some issues i replaced the iwire one with this. It stopped the leaking through the gromet but then with the new one when the tank pressurized slightly due to heat fuel would travel up the centre of the wires through the strands and then came out where the insulation ended which can be slightly seen where the heat shrink and the red wire insulation ends. I've since just got a replacement cradle top and crimped the iwire feed and ground to the factory wiring just before the connector. Might at some point use a stud type solution but kinda over it right now. I've got a small surge tank on the way so the main pump will run 0psi in future so current draw will be down from what it is now anyway. Edited September 28, 2019 by Andy_Mac 2000 Legacy B4 RSK - SOLD 2006 Legacy BP5 GT Spec B wagon - Garage Thread 2011 VW T5 van 2.0L of turbo diesel awesomeness Link to comment Share on other sites More sharing options...
