Huttar13 Posted June 26, 2019 Share Posted June 26, 2019 Hi all Im New to the Subaru work but i have a 2016 legacy 2.5i Premium. Im installing my aftermarket JVC head unit with the meastro Idatalink module and after the install I have no sound coming from the from speakers, Ive tried the stock speakers and new aftermarket ones. I have sound from the rear but not the fronts. The confusing thing is that with the factory radio installed I have no issue with the new speakers or the stock speakers. Anybody run into this issue? I would prefer to not have to run new wire through the doors but Im at a loss here, and so is the Crutchfield tech that Ive been dealing with. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted June 26, 2019 Share Posted June 26, 2019 take radio out of car, put on bench, give it 12V and connect speakers directly to the outputs and see if it works, if it does, check your wiring. Link to comment Share on other sites More sharing options...
tmoney468 Posted June 26, 2019 Share Posted June 26, 2019 (edited) I had the same issue, the fix is this: The issue is that you have removed the Starlink module, which sits below the headunit (See picture attached). The front speaker signals pass through this module, so removing it will also disconnect these speakers. We normally recommend that you retain this module if possible because removing it will eliminate some of the stock features associated with Subaru's eyesight system. Basically you have to keep the small starlink box that sits under the stock stereo, connected to the factory harnesses if you want to keep the front speakers stock. There is a bypass you can get. Sent from my iPhone using Tapatalk Edited June 26, 2019 by tmoney468 Link to comment Share on other sites More sharing options...
Huttar13 Posted June 27, 2019 Author Share Posted June 27, 2019 I had the same issue, the fix is this: The issue is that you have removed the Starlink module, which sits below the headunit (See picture attached). The front speaker signals pass through this module, so removing it will also disconnect these speakers. We normally recommend that you retain this module if possible because removing it will eliminate some of the stock features associated with Subaru's eyesight system. Basically you have to keep the small starlink box that sits under the stock stereo, connected to the factory harnesses if you want to keep the front speakers stock. There is a bypass you can get. Sent from my iPhone using Tapatalk This was it!! Thank you Link to comment Share on other sites More sharing options...
