Center console swap
Posted
What is needed to complete this swap? I'm looking at pulling the trigger on purchasing this and know I'll need other pieces just not sure what else.46bc357b3da952f667ac88952b617d15.jpg
Sent from my SM-N950U1 using Tapatalk
Posted
you will need panel radio , trim radio ,ashtray , shift boot . lower trim panel from a 2008 also.
Yes, it would be this piece. Do you make any of it?[emoji1787][emoji1696]
I'm waiting to hear from the seller to see if they have any of the other pieces available.
Posted
Yes, I just assumed relocating ebrake. Not that easy?
as a fabricator i will say everything is possible , but your are looking for trouble !
:lol:
Posted
There so many things that make different from a 2005 there are to many things to list.
For starters, what would you do with the seat heater switches.
Go find some other places to spend your money on that would make the car perform better.
Engine Build - Click Here
Posted
dont forget everything is slightly angled . i don't think you can match a rhd center console to lhd panel radio .
take the time to find the right pieces , many on the forum did it .
patience will pay !
Posted
^^Madrig has the ideal setup. I’m slowly piecing together a similar setup myself. It seems extensive as he eluded to above but it’s worth it for the aesthetics IMO. I think your focus should be on EDM interior parts but I could be way off because I’m still learning as I go. Cheers boss
Posted
Learning here as well. I've only had the car for a year and a half. This is the first time I've found this piece lhd or rhd for sale. Maybe just looking in the wrong places?
Posted
patience will pay !
[ATTACH]276843[/ATTACH]
I have the rhd radio panel already. Upgrading the stereo was one of the first things I did to the car. The angle is slightly off but noticable with the lhd ash tray.
Very beautiful interior you have.
