where does it go?
Posted
I can't 100% tell but it sort of looks like the heat shield that bolts to the water pump/block.
I'll have to go check. for some reason, I thought it belongs around the turbo area cause it was in my turbo/header pile when doing my build. i will go check if there is a are for it around water pump/block.
Posted
The heat shield is for the turbo or maybe the downpipe's cat. It sort of looks like the heat shield that is in the way of change the waterpump when doing the timing belt...
Posted
Man, I was truly stumped. I was gonna make that shield Optional. really appreciate it.
Posted
That shield goes on the driver side, near the back of the more more.
It’s a shield for the sensors there from the downpipe.
I had the biggest confusion to where it went at first too. But I figured it out.
There’s also a ground strap attach to it from the chassis.
Posted
Thanks for all the help fellas. I was able to sneak it on by removing the cat and lowering the Header, otherwise was near impossible to bolt it in.
