scoobydoobie96 Posted June 11, 2019 Share Posted June 11, 2019 Hi everyone. Ive had my 05 OBXT for about 6 months now, i love it. im starting to replace all the suspension stuff since its worn out. i got Spec B. front control arms and complete rear suspension. i got all my front and rear bushings, the only ones i cant find are for the rear trailing arm/knuckle. since im upgrading all the other bushings i would rather not put OEM bushings back in. i cant seem to find any and was hoping someone may know of something Link to comment Share on other sites More sharing options...
Andy_Mac Posted June 11, 2019 Share Posted June 11, 2019 Assume you're talking about the large front bush on the trailing arm? Whiteline uses poly bushes so can create some noise but will be much firmer than stock, Hardrace is a OEM style bush that uses harder rubber to increase firmness. There are other options out the but those two are a good starting point. https://whitelineperformance.com/collections/all/products/w63398-bushing-kit http://www.hardrace.com/Product_detail.asp?id=2023 2000 Legacy B4 RSK - SOLD 2006 Legacy BP5 GT Spec B wagon - Garage Thread 2011 VW T5 van 2.0L of turbo diesel awesomeness Link to comment Share on other sites More sharing options...
AJs Boom Box Posted July 30, 2021 Share Posted July 30, 2021 Does anyone know if the bushings for the Spec B are different than the GT Front Trailing Arm Bushings. Link to comment Share on other sites More sharing options...
seanyb505 Posted July 30, 2021 Share Posted July 30, 2021 https://legacygt.com/forums/showthread.php/complete-bushing-guide-bl-bp-281856.html Trailing arm front bushings are the same. Link to comment Share on other sites More sharing options...
AJs Boom Box Posted August 2, 2021 Share Posted August 2, 2021 Yea I was on the phone with Subaru and they told me that the bushings are different sizes. Could they be wrong? Link to comment Share on other sites More sharing options...
boxkita Posted August 2, 2021 Share Posted August 2, 2021 Yea I was on the phone with Subaru and they told me that the bushings are different sizes. Could they be wrong? the above link is the definitive guide. subaru is wrong Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
AJs Boom Box Posted August 2, 2021 Share Posted August 2, 2021 Looks like ill have to just reorder and have a backup OEM set . Thanks Link to comment Share on other sites More sharing options...
Max Capacity Posted August 3, 2021 Share Posted August 3, 2021 https://legacygt.com/forums/showthread.php/complete-bushing-guide-bl-bp-281856.html?t=281856 That may help. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
AJs Boom Box Posted August 4, 2021 Share Posted August 4, 2021 Yea seanyb505 jus posted the same link. Thanks guys Link to comment Share on other sites More sharing options...
jaylew Posted August 4, 2021 Share Posted August 4, 2021 that link to all the bushing options, I updated with my list of OE bushings should you choose to stay OE. Wagon is LIFE! - 264,000 miles and climbing Unofficial Build (Restoration) Thread Steering Rack Rebuild Link to comment Share on other sites More sharing options...
AJs Boom Box Posted August 13, 2021 Share Posted August 13, 2021 If I swap over to the spec B trailing arms. What sway bar bracket do i need to keep the sway bars installed? I have the avo ones currently installed. Mechanics say that the spec b trailing arm has bung for a mount but need a bracket to install sway bars. Please help. Im going down there today and will have pictures. He says i can drive it without sway bars but idk. Link to comment Share on other sites More sharing options...
seanyb505 Posted August 14, 2021 Share Posted August 14, 2021 Yeah the aluminum trailing arms have a bracket that the sway bar links bolt to. It's not the avo reinforcement brackets. You can find it on an oem parts site. It's below the trailing arm and bolts to it with 3 bolts. I'll try to find it tomorrow Link to comment Share on other sites More sharing options...
AJs Boom Box Posted August 18, 2021 Share Posted August 18, 2021 Got in touch with Subaru and they were able to get the Spec B Endlink Brackets shipped out. Only had 1 left after ordering mine Link to comment Share on other sites More sharing options...
Infosecdad Posted August 19, 2021 Share Posted August 19, 2021 Cusco also sells a set along with an extra brace for the RSB brackets. I have them, just need the aluminum trailing arms to install... Link to comment Share on other sites More sharing options...
AJs Boom Box Posted August 20, 2021 Share Posted August 20, 2021 (edited) Cusco also sells a set along with an extra brace for the RSB brackets. I have them, just need the aluminum trailing arms to install... You wouldn't happen to have the part number for those? Searching the website, the catalog is in Japanese. I got my Spec B Training Arms from japandirectjapanese.com $350 w/new bushings. Edited August 20, 2021 by AJ's Boom Box Link to comment Share on other sites More sharing options...
Infosecdad Posted August 20, 2021 Share Posted August 20, 2021 I think it's "684 316 A" https://www.vividracing.com/cusco-rear-sway-bar-brackets-p-152666377.html https://www.ebay.com/itm/282777768533 Link to comment Share on other sites More sharing options...
Code Posted August 27, 2021 Share Posted August 27, 2021 I ordered a set of the Cusco brackets last week. Yesterday vividracing contacted me and said 4-6 weeks because they are made-to-order. I’m fine with the wait. Now all I need is all of the oem rear suspension hardware and spec b wheel bearing bolts then I’m ready for the swap "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
AJs Boom Box Posted August 29, 2021 Share Posted August 29, 2021 You can get the wheel bearing bolts from dealership. Like 25 bucks for 8 (rear sets). Tho they will have to order them from warehouse. Link to comment Share on other sites More sharing options...
Code Posted September 21, 2021 Share Posted September 21, 2021 Cusco brackets shipped today. "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
