the.burnttbean Posted May 18, 2019 Share Posted May 18, 2019 Doesn't want to communicate with ECU? Trying to log as my car is backfiring a lot, dies when coming to a stop. Don't know where to go at this point, check the AP Cobb cable looks good. Sent from my SM-G960U using Tapatalk Link to comment Share on other sites More sharing options...
zmadanat Posted June 8, 2019 Share Posted June 8, 2019 I had that problem with a previous 05 LGT... The port had an issue... I'd have to keep wiggling the connector and pushing it in at the right angle to get it to work. I'm glad my new car doesn't have that same issue. Hope that helps! ALSO, that sounds like the the problem that happens with the p0031 code... could be bad AVCS solenoids or cam sensors. Link to comment Share on other sites More sharing options...
