Rockwvu Posted May 10, 2019 Share Posted May 10, 2019 Noticed my wife’s 2015 2.5 (67k miles) smoking at startup from tailpipe. Appears to possibly be a bluish tint but I haven’t examined it closely. Leads me to believe oil burning. It clears up quickly and doesn’t do it when restarted quickly. Seems like it could be valve guides or seals. Anyone know if these engines are prone to this? Any snake oil worth trying? What’s involved in a possible repair? Pulling engine? Still runs good. Getting 29 mpg average. Link to comment Share on other sites More sharing options...
Yoda_One Posted May 10, 2019 Share Posted May 10, 2019 Sure it is not just moisture coming out of the pipe due to condensation. Laughing at oneself and with others is good for the Soul![emoji2] Laughing at Oneself and with Other is good for the Soul Link to comment Share on other sites More sharing options...
ehsnils Posted May 11, 2019 Share Posted May 11, 2019 Pcv valve starting to act up is a possibility. That might cause some oil accumulating in the manifold. Is the oil consumption normal? Link to comment Share on other sites More sharing options...
Rockwvu Posted May 11, 2019 Author Share Posted May 11, 2019 Pcv valve starting to act up is a possibility. That might cause some oil accumulating in the manifold. Is the oil consumption normal? Oil consumption appears normal. I have about 3000 miles on this oil change and looks to be about 3/4 the way between the two holes. ( 3/4 full) I’ll look into the pcv. I would really like that solution! Link to comment Share on other sites More sharing options...
Rockwvu Posted May 11, 2019 Author Share Posted May 11, 2019 So it seems like this is an intermittent problem. I’m now thinking a bad pvc (intermittently) May be the cause. Link to comment Share on other sites More sharing options...
ammcinnis Posted May 11, 2019 Share Posted May 11, 2019 As Yoda_One already asked, are you sure it's oil smoke you're seeing and not just ordinary water vapor condensation? How long does it last? "If you don't know where you're going, any road will take you there." ~ The Cheshire Cat (Alice in Wonderland) Link to comment Share on other sites More sharing options...
Rockwvu Posted May 12, 2019 Author Share Posted May 12, 2019 As Yoda_One already asked, are you sure it's oil smoke you're seeing and not just ordinary water vapor condensation? How long does it last? Yes. It doesn’t appear to be white. And it has occurred after trips Of 20-30 miles so I’m sure it had sufficient heat to burn if condensation. I would say it lasts 5 seconds. Link to comment Share on other sites More sharing options...
Norskie Posted May 12, 2019 Share Posted May 12, 2019 I would suspect oil seeping past the piston rings into the cylinders, where it pools and then burns on start. The PCV valve thing would be an easy thing to check, but a faulty PCV wouldn't push oil into the cylinder when the engine isn't running. I don't think our boxer motors, with horizontal valves, would be prone to valve guide leaks leading to this. On upright engines oil stays pooled in the heads and then leaks down; our engines are more likely to drain back to the crankcase. Inspection by borescope after sitting overnight should be able to confirm that there is oil pooling in the cylinders. There-after dry vs. wet compression tests would indicate ring health, and leakdown test would indicate how much is passing the rings. If you do you have stuck rings, something like a BG44K engine flush could help free them up. EDIT: In the past Subaru boxers were prone to piston slap. Is there a light rattle that goes away once the engine warms up? Link to comment Share on other sites More sharing options...
Rockwvu Posted May 21, 2019 Author Share Posted May 21, 2019 Update: I changed the pcv valve a week ago. I haven’t noticed any smoke at startup. The old valve didn’t rattle like new but it wasn’t plugged either. Maybe occasionally it would allow too much oil by. Pcv valve was fairly easy to change. Nut driver to take Intake hose off of throttle body and a 19mm socket and long extension and wobble is helpful but not necessary. New OEM valve was $20 from amazon. Link to comment Share on other sites More sharing options...
ehsnils Posted May 21, 2019 Share Posted May 21, 2019 If the old didn't rattle then it was ripe for replacement. Give it some time to see if the oil smoke stays away. Link to comment Share on other sites More sharing options...
