Mak2001 Posted May 10, 2019 Share Posted May 10, 2019 Planning on getting xxr 527 for my 2006 legacy gt on stock suspension. Wondering what the biggest size i can get is without messing around with fenders or stretching tires a lot. Would 18x8.75 +35 work? Or would 17s be the best? Thanks Sent from my iPad using Tapatalk Link to comment Share on other sites More sharing options...
boxkita Posted May 10, 2019 Share Posted May 10, 2019 Did you read the sticky at the top of the section? "FAQ: Offets, Sizes for Rims and Tires" ? link: https://legacygt.com/forums/showthread.php/faq-offsets-sizes-rims-and-tires-gt-xenonk-version-vol-262472.html wagon vs sedan matters, too Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
Notorious Posted May 10, 2019 Share Posted May 10, 2019 You’ll need to roll fenders with a slight pull depending on tire choice. Roll fenders for sure. Link to comment Share on other sites More sharing options...
boxkita Posted May 10, 2019 Share Posted May 10, 2019 18x8.75 is beyond the limit of the wheel well on a wagon and close to being outside the sedan's, too. Putting a tire on that rim without stretching or rolling the fender is going to require a rubber band tire. a 265/30/18 would be a good fit if you could find one. It would rub badly everywhere tho Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
whitetiger Posted May 10, 2019 Share Posted May 10, 2019 on stock suspension, wheels like that will look awful. a 17x8 or 18x8 +48 with a 245/40/17 or a 245/35/18 tire will be best. Link to comment Share on other sites More sharing options...
boxkita Posted May 10, 2019 Share Posted May 10, 2019 ^^^ this. from someone who did alot of tire/wheel testing Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
whitetiger Posted May 10, 2019 Share Posted May 10, 2019 way too much testing. Link to comment Share on other sites More sharing options...
lazybummm Posted May 10, 2019 Share Posted May 10, 2019 way too much testing. A lot of people said to me 18x8 is too narrow for 245....and advised me to go with 235 40 18 instead...I'm still struggling between the two. Link to comment Share on other sites More sharing options...
whitetiger Posted May 10, 2019 Share Posted May 10, 2019 (edited) they are wrong. 245 is just fine on a 8" wide wheel. FWIW its the same proportions as putting a 225 on a 7" wide wheel. and people do that all the time. 1"~ 25mm. So for whoever told you that, remind yourself not to listen to them. Edited May 10, 2019 by whitetiger Link to comment Share on other sites More sharing options...
awfulwaffle Posted May 13, 2019 Share Posted May 13, 2019 (edited) Confirmed. Went with a 245 40 17 on an 8" wheel, convinced by Xenonk's tire fitment thread. Tiniest bit of pinch, but it's fine. No roll or pull needed with a 45 offset with Hankook V12 Evos, others may need a bit. I'm lowered about an inch too, with max negative factory camber up front and -2 rear. Edited May 13, 2019 by awfulwaffle Link to comment Share on other sites More sharing options...
fedaykin Posted May 14, 2019 Share Posted May 14, 2019 245 on a 8" is fat. Also, great choice of tyre. Link to comment Share on other sites More sharing options...
