RIVERWHITE Posted April 30, 2019 Share Posted April 30, 2019 HI "Team"! I, my mechanics and now the local dealer in Colorado are all a little stumped on this so I am putting it out to the forum: I have a 2008 Leggy GT Limited stage 2 that has a "shuddering" coming from the front passenger suspension/wheel area when turning only (it can be a small turn, large turn, slow or at speed. It feels as though the wheel lugs are loose and the rim is slipping a little "out/in". I have replaced the lower control arm bushings (front and rear) the arm is fine and the ball joints too according to all the mechanics in on this, and just now replaced a steering rack:eek: well the issue is still present... The system has been bled properly and everyone is kind of scratching their heads now while I am left with an undrivable car and $$$$ spent on fixes that didn't fix it:confused: Any Suggestions or anyone run into this before? I would love to have some help on this one from the best resource team out there!!!!! Thanks all! Link to comment Share on other sites More sharing options...
Notorious Posted April 30, 2019 Share Posted April 30, 2019 Wheel bearing or loose axle nut. Link to comment Share on other sites More sharing options...
Darth SpecB Posted May 1, 2019 Share Posted May 1, 2019 Check the CV axles. Mine made a similar sound before they started to go out. Sent from my SM-G950U using Tapatalk Link to comment Share on other sites More sharing options...
whitetiger Posted May 1, 2019 Share Posted May 1, 2019 cv axle probably, or front diff damage worst case scenario. Link to comment Share on other sites More sharing options...
