honeybunch2222 Posted April 20, 2019 Share Posted April 20, 2019 Hello there, I have a little problem with my turbosmart dual port BOV. I have just bought a Turbosmart dualport BOV, used one, second hand, I have install it, but at softest or hardest setting when I rev the car on neutral the BOV stay stuck, my car is on 4 jackstand right now and I can't drive it for now. But is it normal that the piston dosen't move if I rev the car on neutral? I dissamble it, and clean the piston and o ring, I put oil on it but the piston is very hard to move, I don't know if I must replace the o ring and the spring. Someone has hint about that problem? How can I test the BOV ? I have removed the 2 oring inside the housing and the piston move freely . I have tried it like that with the spring installed but I have the same problem. There is not enough boost to move the piston in the bov when you don't drive? My car is a Legacy GT 2008 stock. Thanks Link to comment Share on other sites More sharing options...
autoximpreza Posted April 22, 2019 Share Posted April 22, 2019 When there is no load on the engine it will not build enough pressure to open it. Sent from my iPad using Tapatalk Link to comment Share on other sites More sharing options...
honeybunch2222 Posted April 23, 2019 Author Share Posted April 23, 2019 When there is no load on the engine it will not build enough pressure to open it. Sent from my iPad using Tapatalk Thank you bery much, I have order the o ring set and I will test that on road. :) Link to comment Share on other sites More sharing options...
GEE-OTTO Posted April 29, 2019 Share Posted April 29, 2019 When there is no load on the engine it will not build enough pressure to open it. Sent from my iPad using Tapatalk Revs = Load On the stand or the street revving makes boost and the operation of the BOV/BPV is the same when the throttle plate closes. If you rev the engine and let off the throttle, when the BOV isnt venting, is it causing turbo flutter? The pressure has to go somewhere, if you hear nothing are you sure you have the induction system plumbed correctly? Do you have the valve set up correctly, per the manufacturers instructions? Link to comment Share on other sites More sharing options...
honeybunch2222 Posted May 1, 2019 Author Share Posted May 1, 2019 Revs = Load On the stand or the street revving makes boost and the operation of the BOV/BPV is the same when the throttle plate closes. If you rev the engine and let off the throttle, when the BOV isnt venting, is it causing turbo flutter? The pressure has to go somewhere, if you hear nothing are you sure you have the induction system plumbed correctly? Do you have the valve set up correctly, per the manufacturers instructions? The turbo don' seem to flutter but I hear some little back fire on the exhaust. I have try at the softest and hardest setting on bov, same problem. The vacuum work properlly. I remove the vacuum hose and the engine seems to stall(normal) I suspect a leak with the bov Link to comment Share on other sites More sharing options...
