Abelr Posted April 17, 2019 Share Posted April 17, 2019 Ok so brief history of the car is a complete new everything under the hood 60k ago. Immediately pulled banjo bolt filters and intalled catless up and down pipe and had a tune flashed(Tuning Alliance) been religious about oil changes and maintenance since the new motor/turbo went in. My thoughts are okay how much life does a vf40 have in those conditions before I should start considering a replacement.? I’m getting ready to do injectors coil packs spark plugs etc so if it’s nearing the end if it’s life I will upgrade and thus match the supportive components to the new turbo. Any input much appreciated. Thanks Link to comment Share on other sites More sharing options...
awfulwaffle Posted April 17, 2019 Share Posted April 17, 2019 On my current car, original turbo went around 140k. Why not pull the DP and check for shaft play? Link to comment Share on other sites More sharing options...
Max Capacity Posted April 20, 2019 Share Posted April 20, 2019 https://legacygt.com/forums/showthread.php/142-000-miles-oem-turbo-168561.html That's my story. Not sure if I have that video saved any where else. Sorry. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
