rommelcake Posted April 16, 2019 Share Posted April 16, 2019 Hey everyone. My wife's 09 Forester XT spun a bearing. Bought a used 08 Legacy GT motor and threw it in. It runs great, but obviously we're driving it like a granny. I have a Tactrix cable and RomRaider setup, all that jazz. My question is, can I flash the stock 08 Legacy ECU into the forester? I know they have different transmissions, not sure if that would have any effect. I did post over to the RomRaider forums, but apparently nobody wants to answer or point me in the right direction. I did reach out to a few tuners, but I don't have $300+ for a tune so soon after buying a new motor. Link to comment Share on other sites More sharing options...
dgoodhue Posted April 16, 2019 Share Posted April 16, 2019 My question is, can I flash the stock 08 Legacy ECU into the forester? I know they have different transmissions, not sure if that would have any effect. No Link to comment Share on other sites More sharing options...
NORULZleggy Posted April 16, 2019 Share Posted April 16, 2019 Wait, and save up the money and do it right and get a real nice tune. Or visit BOOM town. Link to comment Share on other sites More sharing options...
rommelcake Posted April 16, 2019 Author Share Posted April 16, 2019 Wait, and save up the money and do it right and get a real nice tune. Or visit BOOM town. I'm not in any real danger in the meantime as long as we keep it out of boost, right? Link to comment Share on other sites More sharing options...
Max Capacity Posted April 16, 2019 Share Posted April 16, 2019 Yes stay out of boost. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
waltm Posted April 18, 2019 Share Posted April 18, 2019 Did you only swap in the long block and are using the original ecu, turbo, etc from the FXT? Wouldn't that run fine on the original tune? Link to comment Share on other sites More sharing options...
Shawn06SpecB Posted April 18, 2019 Share Posted April 18, 2019 From what I can tell the XT had a slightly higher CR (8.4:1 vs 8.2:1), there might be other differences as well. Heads etc. You have the tactrix cable but you'll need a wideband O2 in order to get it properly tuned. Link to comment Share on other sites More sharing options...
rommelcake Posted April 18, 2019 Author Share Posted April 18, 2019 It's using the GT Turbo, but Forester ECU. Link to comment Share on other sites More sharing options...
Shawn06SpecB Posted April 18, 2019 Share Posted April 18, 2019 It's using the GT Turbo, but Forester ECU. So you have a VF40 in there and removed a TD04? which injectors and TMIC did you stick with? Link to comment Share on other sites More sharing options...
rommelcake Posted April 19, 2019 Author Share Posted April 19, 2019 VF46, but yes we took out the TD04 with the blown engine. Injectors and TMIC are from the forester. Link to comment Share on other sites More sharing options...
moral hazard Posted April 20, 2019 Share Posted April 20, 2019 (edited) I replied over at romraider but basically I think the easiest way forward would be to open both ROMs in romraider, use the Compare function. Then copy the tables that are different, one at a time over to the forester rom. Then change the injector scalar to suit your injectors. If you want the tune to be a bit more spicy then copy the tables from this base map (or similar): https://www.romraider.com/forum/viewtopic.php?f=29&t=4254 Note, you might find some tables are not the same size between the 2 ROMs, that's where you may need to change the scale on the x-axis in ECUflash and also use the interpolation feature in romraider for the data to be close enough. Edited April 20, 2019 by moral hazard Link to comment Share on other sites More sharing options...
covertrussian Posted April 22, 2019 Share Posted April 22, 2019 From what I can tell the XT had a slightly higher CR (8.4:1 vs 8.2:1), there might be other differences as well. Heads etc. You have the tactrix cable but you'll need a wideband O2 in order to get it properly tuned. 07+ LGT's switched to higher compression motors too. VF46, but yes we took out the TD04 with the blown engine. Injectors and TMIC are from the forester. If you are running the TD04, Forester Injectors and TMIC you should be fine with the STOCK FXT tune. As far as I can remember 2009 FXT EJ's are pretty much identical to the LGT EJ's. I would not bother with LGT tune because it's meant for a bigger turbo and more boost. Plus it wont be as auto-friendly. 05 LGT 16G 14psi 290whp/30mpg 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg Link to comment Share on other sites More sharing options...
rommelcake Posted April 22, 2019 Author Share Posted April 22, 2019 07+ LGT's switched to higher compression motors too. If you are running the TD04, Forester Injectors and TMIC you should be fine with the STOCK FXT tune. As far as I can remember 2009 FXT EJ's are pretty much identical to the LGT EJ's. I would not bother with LGT tune because it's meant for a bigger turbo and more boost. Plus it wont be as auto-friendly. The Forester is running with the bigger VF46. I'm talking with a tuner now and we're going to do an e-tune and run with it from there. Link to comment Share on other sites More sharing options...
covertrussian Posted April 22, 2019 Share Posted April 22, 2019 Running VF46 with forester's tune should be okish still. Forester ECU is calling for about 3* more timing, but since wastegate table summons 3-4psi less boost, it should be a wash. The issue that you would probably run into is with the wastegate. If the VF46 has a stiffer initial spring, the duty cycles would be off, but this is easy to see/check by doing a single pull and logging the peak boost. Anyway, good call on just getting it e-tuned, that is obviously the safest bet. 05 LGT 16G 14psi 290whp/30mpg 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg Link to comment Share on other sites More sharing options...
