Miro Posted April 10, 2019 Share Posted April 10, 2019 Hey guys, long time no see. I still have the hidden sub enclosure, and it's taking up space in my garage. I'd love to have it go to a new home, and I'm lowering the price of both sub and trunk enclosure to $100 + shipping. Just the MB Quart sub was $100 when I bought it from Coppertone, so I hope this can finally depart my garage. The details: * Custom trunk enclosure w/your choice of sub - $100 + shipping, or free pickup. The custom sub enclosure was built by one of our members, ItalynStylion. When installed in a 5th gen Legacy, it goes into the space between the spare tire and the trunk itself (replaces the foam cubby thing) -- so you still preserve your entire trunk capacity, while adding a lot of bass! Your choice of sub includes either: ** An MB Quart 10" sub that I bought from Coppertone, that has <10 hours of play on it before I sold the Subaru, or ** The original Kicker 10CVX104 sub that I had in there. Due to its raised rubber surround, the Kicker developed a hole from scuffing the bottom of the spare tire cover -- so I cleaned and patched the hole with rubber sealant. This is why the sub enclosure now has a square black frame -- to prevent the spare tire cover from rubbing on top of the sub enclosure when a heavy load is placed in the trunk. By comparison to the Kicker, the MB Quart doesn't have a raised surround, so potential rubbing is way less of an issue. It has no damage on its face. I can put in whichever sub you'd like. Pickups can be arranged if you're in the Central Coast area of California, or if you're passing through! Link to comment Share on other sites More sharing options...
Chillwill007 Posted April 10, 2019 Share Posted April 10, 2019 What is the rms of the mb quart sub? And what is shipping to NJ 08080 Link to comment Share on other sites More sharing options...
Miro Posted April 11, 2019 Author Share Posted April 11, 2019 What is the rms of the mb quart sub? And what is shipping to NJ 08080 Here are specs I could dig up: Specifications (parallel V.C.s): * Power handling: 300 watts RMS/750 watts max * Voice coil diameter: 3" * Nominal impedance: 2 ohms * Re: 1.6 ohms * Freq response: 21-300 Hz * Fs: 28 Hz *SPL: 93 dB 2.83V/1m * Vas: 2.15 cu. ft. * Qms: 6.6 * Qes: .52 * Qts: .48 * Xmax: 9.5 mm For a 30 x 30 x 20" package, that weighs 40 lbs, UPS wants $150 for Ground delivery I put those numbers in as rough guesses, so if you're still interested, I can get an official quote once I hunt down a box and the such. Also, if you have an account with a corporate discount and you can send me a label that way, obviously there will be no charge for shipping on my end. Link to comment Share on other sites More sharing options...
Miro Posted April 24, 2019 Author Share Posted April 24, 2019 Bump for good measure! Link to comment Share on other sites More sharing options...
