Joser619LGT Posted April 9, 2019 Share Posted April 9, 2019 Does anyone have catted uppipe they want to sell? I'm in desperate need of one to get my car back running. Thanks in Advance Link to comment Share on other sites More sharing options...
Infosecdad Posted April 9, 2019 Share Posted April 9, 2019 I have one, didn't think anyone would ever want to buy it... Link to comment Share on other sites More sharing options...
Joser619LGT Posted April 9, 2019 Author Share Posted April 9, 2019 How much do you want for it? I just want to get my car to pass smog and get it running since my other car got totaled a couple weeks ago. Link to comment Share on other sites More sharing options...
Infosecdad Posted April 9, 2019 Share Posted April 9, 2019 Dang it, mine went to recycling a couple months ago. Someone find this guy a catted up-pipe from their OEM stash! Link to comment Share on other sites More sharing options...
bemani Posted April 9, 2019 Share Posted April 9, 2019 I didn't think you would need the uppipe cat to pass smog? Will that be your only cat? Link to comment Share on other sites More sharing options...
Joser619LGT Posted April 10, 2019 Author Share Posted April 10, 2019 I didn't think you would need the uppipe cat to pass smog? Will that be your only cat? The check engine light is on and my mechanic tried gutting it but I don't want any metal pieces messing up my turbo. Link to comment Share on other sites More sharing options...
Infosecdad Posted April 10, 2019 Share Posted April 10, 2019 Is the check engine light because of the EGT sensor that’s normally in the up-pipe? You can put a resistor in the to take care of that if the case. Link to comment Share on other sites More sharing options...
AWDFTW Posted April 10, 2019 Share Posted April 10, 2019 Gutting the uppipe won't cause a CEL. What code(s) are there? Link to comment Share on other sites More sharing options...
Joser619LGT Posted April 10, 2019 Author Share Posted April 10, 2019 Check engine light came on for the 02 sensors. I replaced all 3 I believe but the check engine light was still on. The car stutters on all gears so the mechanic told me that it was the catalytic converter on top. Don't know much about cars other than the basics so I'm just trying to get the uppipe to see if it really going to fix the problem Link to comment Share on other sites More sharing options...
Shawn06SpecB Posted April 10, 2019 Share Posted April 10, 2019 P0545 and P0546 Link to comment Share on other sites More sharing options...
Joser619LGT Posted April 10, 2019 Author Share Posted April 10, 2019 I didn't think you would need the uppipe cat to pass smog? Will that be your only cat? Gutting the uppipe won't cause a CEL. What code(s) are there? I'll get the codes tomorrow when my pops brings back the scanner. Link to comment Share on other sites More sharing options...
snm95ls Posted April 10, 2019 Share Posted April 10, 2019 P0545 and P0546 You should be able to get rid of those with EGT bypass documented on here. Basically just installing a resister in place of the EGT probe. I think I still have the catted UP from my car hanging out somewhere if you decide you still need one. Link to comment Share on other sites More sharing options...
Joser619LGT Posted April 10, 2019 Author Share Posted April 10, 2019 You should be able to get rid of those with EGT bypass documented on here. Basically just installing a resister in place of the EGT probe. I think I still have the catted UP from my car hanging out somewhere if you decide you still need one. I'll try this on the weekend since I work long hours. I'll still buy the UP if you still have it? Link to comment Share on other sites More sharing options...
Shawn06SpecB Posted April 11, 2019 Share Posted April 11, 2019 You should be able to get rid of those with EGT bypass documented on here. Basically just installing a resister in place of the EGT probe. I think I still have the catted UP from my car hanging out somewhere if you decide you still need one. I didn't say you couldn't get rid of them just listing them so the OP knows what to look for or which to turn off via an OS tune etc. Link to comment Share on other sites More sharing options...
Joser619LGT Posted April 11, 2019 Author Share Posted April 11, 2019 I'm getting code P0031 twice and P0037 Link to comment Share on other sites More sharing options...
snm95ls Posted April 13, 2019 Share Posted April 13, 2019 I didn't say you couldn't get rid of them just listing them so the OP knows what to look for or which to turn off via an OS tune etc. Right. Didn't track usernames closely, and thought OP was posting the codes currently present. I'm getting code P0031 twice and P0037 https://www.obd-codes.com/p0031 https://www.obd-codes.com/p0037 Seems odd that both pre and post cat oxygen sensors have the same issue. Sounds like you have some wiring issues, or maybe the heater element in both sensors happens to be open/defective. Sometimes, there is a fuse for the O2 heaters, so if that is blown for some reason, that could result in these codes. Link to comment Share on other sites More sharing options...
