10 secs Posted March 31, 2019 Share Posted March 31, 2019 I have a 2005 Legacy GT wagon 5 speed. I need a new transmission. Will the transmission from a 2008 Impreza 2.5 (5 speed) work with my car? Any input is valuable to me. Link to comment Share on other sites More sharing options...
SesnaBlue Posted March 31, 2019 Share Posted March 31, 2019 I’m pretty sure it will bolt up no problem. But you want to check the gear ratios I would bet they are different on 2.5i vs a turbo. Also check that the clutch is the same style (push vs pull). Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted March 31, 2019 Share Posted March 31, 2019 (edited) Check the sticky at top of the tranny forum. Edited March 31, 2019 by Max Capacity 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
