Tonylty929 Posted March 29, 2019 Share Posted March 29, 2019 I'm looking for turbo timer for my 2008 legacy GT Wagon, I tried the Apexi turbo timer but not work with the push start button Link to comment Share on other sites More sharing options...
whitetiger Posted March 29, 2019 Share Posted March 29, 2019 you dont need one. they are a waste of money on these cars with the stock coolant system doing the job even when the car is off. Link to comment Share on other sites More sharing options...
Max Capacity Posted March 29, 2019 Share Posted March 29, 2019 You don't need a turbo timer with these water cooled turbo's. If you drive it hard just drive it easy for the last few minutes of the drive. I normally put my wagon in neutral and coast off the exit ramps after a highway drive. Even if you shut the engine off the way the system is plumbed it will flow a little water through the turbo, so I've been told. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it.  Engine Build - Click Here Link to comment Share on other sites More sharing options...
whitetiger Posted March 29, 2019 Share Posted March 29, 2019 yep. thermal siphoning through fluid convection with the secondary tank and cap sitting right above the turbo. Link to comment Share on other sites More sharing options...
Tonylty929 Posted March 30, 2019 Author Share Posted March 30, 2019 Thank you for the advice Link to comment Share on other sites More sharing options...
