nettkonge Posted March 28, 2019 Share Posted March 28, 2019 hi all i am thinking to buy a 06 to 08 jdmsubaru legasy gb spec b ore tunde by sti and i was thinging to convert from RHD to LHD eny one know if this is straight forward ore not Link to comment Share on other sites More sharing options...
59ctd Posted March 28, 2019 Share Posted March 28, 2019 (edited) Initial thought is that it would be a massive undertaking and very costly as well since the entire dash, all the pedals, brake master cylinder, steering, steering rack, probably a large portion of the electrical wiring harness, HVAC system and many more items would also have to be swapped out. Edited March 28, 2019 by 59ctd Link to comment Share on other sites More sharing options...
DaveWaters Posted March 28, 2019 Share Posted March 28, 2019 Wait .. what? ...Why? Do they not allow rhd cars on the road in Norway? I’d think a lot of of the coolness factor of jdm is being rhd. I can only imagine the headache of converting. Probably would need a complete lhd donor. Link to comment Share on other sites More sharing options...
chato Posted March 28, 2019 Share Posted March 28, 2019 would be a nightmare to piece together parts unless you have a lot of junkyards around, and all the cheap front clips are JDM Link to comment Share on other sites More sharing options...
JmP6889928 Posted March 29, 2019 Share Posted March 29, 2019 Whew. I can't imagine how much work that would be. Definitely NOT worth it. Link to comment Share on other sites More sharing options...
ehsnils Posted March 29, 2019 Share Posted March 29, 2019 (edited) Not worth it. If you plan to do morning paper delivery then it would be worth to get a RHD. But if you look at importing European cars like luxury BMWs or even higher rated from Japan, then they are often LHDs and only need some minor adjustments to be usable in Europe. Now with Brexit it's actually going to be harder - because first you import them from Japan to UK, then from UK to any other Euro country. Actually cheaper than doing a direct import because the UK regulations are more forgiving. Edited March 29, 2019 by ehsnils Link to comment Share on other sites More sharing options...
nettkonge Posted March 29, 2019 Author Share Posted March 29, 2019 i was thinging to use my 07 legacy as a donor car for steering part and dach Link to comment Share on other sites More sharing options...
