legacynub Posted March 13, 2019 Share Posted March 13, 2019 So long story short, my 05 legacy GT is approaching 180k miles. what are some of the must dos for the 180k service? timing belt, coolant flush, water pump? Also I'm torn between selling the car and keeping it. I currently have a civic also and a impreza which all in all do the same things. why do you keep your legacy gt? Link to comment Share on other sites More sharing options...
Rhitter Posted March 13, 2019 Share Posted March 13, 2019 Timing belt is 100k miles. If it hasn't been done it needs to be done ASAP. To get to the timing belt you remove the radiator. Might as well put new coolant in. Because the water pump is right there, might as well change it. At 180k I would also do all the pulleys. My OBXT build Link to comment Share on other sites More sharing options...
legacynub Posted March 13, 2019 Author Share Posted March 13, 2019 Timing belt is 100k miles. If it hasn't been done it needs to be done ASAP. To get to the timing belt you remove the radiator. Might as well put new coolant in. Because the water pump is right there, might as well change it. At 180k I would also do all the pulleys. timing belt and stuff was done at about 90k, should i replace it again? for the pulleys, should i go lightweight pulleys or oem? the car is tuned supposedly by infamous1 but don't have a record of it. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted March 13, 2019 Share Posted March 13, 2019 I would not go lightweight crank pulley. I have one, but after doing some more reading and stuff, they're not really that worth it and good for the engine. Keep your stock one. Just make sure it is still in good shape. Link to comment Share on other sites More sharing options...
Max Capacity Posted March 13, 2019 Share Posted March 13, 2019 You can wait another 15,000 before the TB kit is replaced. Are you changing the rear diff and front diff fluids every 30,000 miles ? How do you think the other cars do the same thing, do they push you back in the seat like the GT when you go to WOT ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
legacynub Posted March 14, 2019 Author Share Posted March 14, 2019 You can wait another 15,000 before the TB kit is replaced. Are you changing the rear diff and front diff fluids every 30,000 miles ? How do you think the other cars do the same thing, do they push you back in the seat like the GT when you go to WOT ? tb is the throttle body correct? the whole thing needs to be replaced? yeah, i recently did the clutch also and drained the diff fluid again but i've been changing it ever 30k miles to answer the pushing back in the seat, in my '18 civic with the ktuner + intake my gf said she felt her soul leave her body haha, but it does not hot have a sun roof or heated seats which is a major bummer but the legacy has that. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted March 14, 2019 Share Posted March 14, 2019 how much torque in the civic? Link to comment Share on other sites More sharing options...
legacynub Posted March 14, 2019 Author Share Posted March 14, 2019 according to ktuner https://ktuner.com/16civicturbo/ 260? if i'm reading it correctly. i loaded their stage 2 onto it Link to comment Share on other sites More sharing options...
Rhitter Posted March 15, 2019 Share Posted March 15, 2019 tb is the throttle body correct? the whole thing needs to be replaced? yeah, i recently did the clutch also and drained the diff fluid again but i've been changing it ever 30k miles to answer the pushing back in the seat, in my '18 civic with the ktuner + intake my gf said she felt her soul leave her body haha, but it does not hot have a sun roof or heated seats which is a major bummer but the legacy has that. TB is normally throttle body. But I think Max meant timing belt in this case. Old people these days. To lazy to type out full words. My OBXT build Link to comment Share on other sites More sharing options...
