CamaroSS2000 Posted March 11, 2019 Share Posted March 11, 2019 Is it just moisture???? Anyone else have this issue? Link to comment Share on other sites More sharing options...
ehsnils Posted March 11, 2019 Share Posted March 11, 2019 Check the tension. It might be time for a new belt too. Also check belt pulleys - a bad pulley bearing can also squeak, but you have to loosen the belt to check that. Link to comment Share on other sites More sharing options...
ammcinnis Posted March 11, 2019 Share Posted March 11, 2019 Belt noise is not normal, whether moisture is present or not. The 2.5 engine uses an automatic belt tensioner, which should compensate for temperature changes and belt stretch. (The belt tensioner on the 3.6 is manually adjusted.) Remove the belt and check it for wear, cracks, and/or glazing. Check the tensioner for free operation, and check that the tensioner pulley and all idler pulleys turn smoothly. You don't say how many miles on your Legacy. Depending on age and mileage, I would probably just install a new belt and possibly replace the tensioner and idler pulleys. "If you don't know where you're going, any road will take you there." ~ The Cheshire Cat (Alice in Wonderland) Link to comment Share on other sites More sharing options...
RWebb Posted March 11, 2019 Share Posted March 11, 2019 Belt noise is not normal, whether moisture is present or not. The 2.5 engine uses an automatic belt tensioner, which should compensate for temperature changes and belt stretch. (The belt tensioner on the 3.6 is manually adjusted.) Remove the belt and check it for wear, cracks, and/or glazing. Check the tensioner for free operation, and check that the tensioner pulley and all idler pulleys turn smoothly. You don't say how many miles on your Legacy. Depending on age and mileage, I would probably just install a new belt and possibly replace the tensioner and idler pulleys. This is why you are a mod and everyone should ignore ehsnils Link to comment Share on other sites More sharing options...
CamaroSS2000 Posted March 13, 2019 Author Share Posted March 13, 2019 I have 65K on it. Now since i posted this it hasnt made the noise. Link to comment Share on other sites More sharing options...
tmoney468 Posted March 14, 2019 Share Posted March 14, 2019 Also good to fix squeak as soon as possible, as allowing it to continue can glaze the pulleys = a bigger job. Glad you had it resolved Link to comment Share on other sites More sharing options...
capttris Posted March 15, 2019 Share Posted March 15, 2019 with 95,000 miles on my 2013, I get a little squeak on a really damp morning, OR after I clean and hose lightly under the hood, so the belt would be totally wet. Otherwise it's quiet Link to comment Share on other sites More sharing options...
