Jimmyk Posted March 4, 2019 Share Posted March 4, 2019 Ok, I tried everything...trip A is currently on the speedometer. It won’t go to trip b and won’t reset either. My wife is driving the car today, but I heard other members saying they removed the negative battery cable for a few minutes and reset the computer. Did anyone have any experience with this problem? If so how did you fix it? Link to comment Share on other sites More sharing options...
cww516 Posted March 4, 2019 Share Posted March 4, 2019 Could be that a reset will fix it, or it could just be that the switch itself isn't working, since both switching and resetting are on that same switch. I'm not going to suggest you beat the crap out of it, but if it wasn't used much (and assuming it's a membrane switch inside the gauge cluster and not a microswitch), you might be able to do a little press and wiggle action to clean off the contacts. I know the cruise control functions on my Baja (which are membrane switches) were a little flaky right when I bought it with 173k miles on the clock, likely due to lack of use, and with a little love, it's back to working order now. Link to comment Share on other sites More sharing options...
Jimmyk Posted March 5, 2019 Author Share Posted March 5, 2019 Thanks for the info, I bought this 2014 Legacy last week . The trip guage is on 90@@ miles,so it may have been like this for a while . The car currently has 130,000 miles on it . Link to comment Share on other sites More sharing options...
FLlegacy Posted March 5, 2019 Share Posted March 5, 2019 Make sure you are pressing the correct button on the left side of the cluster, assuming it's like the 2010 cluster that is. The right side button is for the information read out. Sent from my SM-G965U using Tapatalk Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted March 7, 2019 Share Posted March 7, 2019 (edited) buttons do the same for the 13+ cars regardless of cluster used. Left is trip select on short press and reset on a long hold Right is MPG info changer on short press and reset on a long hold. Edited March 7, 2019 by YeuEmMaiMai Link to comment Share on other sites More sharing options...
Jimmyk Posted March 9, 2019 Author Share Posted March 9, 2019 Definitely pressing the right button, Link to comment Share on other sites More sharing options...
NVAKeith Posted March 9, 2019 Share Posted March 9, 2019 Definitely pressing the right button, There’s the problem, the you should try the left one. Link to comment Share on other sites More sharing options...
DrD123 Posted March 9, 2019 Share Posted March 9, 2019 Could be that the switch on the board inside the cluster has been damaged - perhaps by the previous owner smashing it too hard or something... it's probably a surface mount device of some sort. I haven't seen anyone take a 2014 gauge cluster apart, but it shouldn't be too difficult - the question is how much access do you have to the switches without having to get into the business of pulling needles, etc. which would not be a good idea... Link to comment Share on other sites More sharing options...
FLlegacy Posted March 9, 2019 Share Posted March 9, 2019 There seems to be some odd electrical issues with this car, was it a salvage? Sent from my SM-G965U using Tapatalk Link to comment Share on other sites More sharing options...
Jimmyk Posted March 10, 2019 Author Share Posted March 10, 2019 No, it has a clean title. Although the previous owner drove the heck out of the car. It’s a 2014 with 130,000 miles on it. Link to comment Share on other sites More sharing options...
