bowenx Posted February 25, 2019 Share Posted February 25, 2019 Hey folks, I have approx 44k miles on the '15 legacy 3.6 and the brakes feel warped again. The dealer had 'turned' them at @36k miles as they did have a warp to them. So the question, have any of you upgraded rotors/pads or just stick with oem? My prior car was an 02 wrx with several mods, some of which were brakes, that car stopped dreat. Thanks Link to comment Share on other sites More sharing options...
Norskie Posted February 25, 2019 Share Posted February 25, 2019 I've always struggled with Subaru brakes, they aren't the best quality. I've experienced the exact same issues as you, with two separate culprits: 1. Seized caliper at about 95k. I found a rebuild kit for ~ $10/caliper and that solved it for another 100k miles. 2. Seized caliper slides. Shop used wrong lube which caused the rubber bits to swell. Solution was to disassemble, replace with new rubber bits and proper lube. And stop taking the car to a shop. Generally I'll have the rotors turned ($10/each at a local shop) IF they weren't already warped. If warped I toss them and buy quality aftermarket rotors at 1/3 the cost of the Subaru units (if you get ones with unpainted center hats then paint them yourself or they'll rust and be ugly). Link to comment Share on other sites More sharing options...
gathermewool Posted February 25, 2019 Share Posted February 25, 2019 It seems odd that they would turn warped rotors. It's seems more likely to me that you've got pad deposition onto the rotor and they cleaned the rotor. Are you a heavy braker? '15 FB25 Magnatec 0W-20 + FU filter (70,517 miles) RSB, Fr. Strut Bar, Tint, STI BBS, LED er'where Link to comment Share on other sites More sharing options...
ammcinnis Posted February 25, 2019 Share Posted February 25, 2019 ... have any of you upgraded rotors/pads or just stick with oem? As long as they are working properly, the OE Legacy brakes are fully adequate. "If you don't know where you're going, any road will take you there." ~ The Cheshire Cat (Alice in Wonderland) Link to comment Share on other sites More sharing options...
chowser51 Posted February 25, 2019 Share Posted February 25, 2019 Did the fancy slotted ones in the front. Not worth it. Used plain old rotors by centric in the back. Works great and not expensive. I did like the ebc red pads. I might used them on my bmw when it’s time for brakes. Link to comment Share on other sites More sharing options...
bowenx Posted February 25, 2019 Author Share Posted February 25, 2019 i had thought they would have just replaced the warped rotors - but they said that they were able to turn them and still be in spec etc. The pulsing / shudder feeling is back (no, no the ABS type feeling). At my last oil change they said they checked and found them still ok. As for being a hard braker - maybe? but i'm not on the brakes that hard for that long so i am surprised that they had warped to begin with. On my WRX i had swapped rotors and pads around due to autox season and was impressed with the braking with some of the pad combos, but with this being my DD and a respectable looking vehicle i don't want any brake squealing from performance pads - thus asking what others have done. thanks for the input folks Link to comment Share on other sites More sharing options...
gathermewool Posted February 26, 2019 Share Posted February 26, 2019 Being hard on the brakes won't usually cause warping, unless you're using janky ass rotors. Braking hard and then stopping hot, with the brake pedal depressed with some force may result in pad deposition, which will give symptoms similar to a warped rotor. '15 FB25 Magnatec 0W-20 + FU filter (70,517 miles) RSB, Fr. Strut Bar, Tint, STI BBS, LED er'where Link to comment Share on other sites More sharing options...
bowenx Posted February 26, 2019 Author Share Posted February 26, 2019 Being hard on the brakes won't usually cause warping, unless you're using janky ass rotors. Braking hard and then stopping hot, with the brake pedal depressed with some force may result in pad deposition, which will give symptoms similar to a warped rotor. Understood - i'm not really doing any of that. Most of my driving is all of 20 min each way to work and on occasion going to a client site which is another 20 min away via highway. I'm not hammering on the brakes on the offramps either - just driving what i would consider as normal. The dealer never said 'deposits' and had said they did notice a warp thus turned them while under warranty. When i used to swap out brakes on my wrx it was fairly easy - so just trying to see if others have opted to go aftermarket or just stuck with oem. I'm not opposed to oem but if they are going to warp for no real reason then i'm leaning towards aftermarket to see if they are better. also to note - the brakes are totally stock (as it the whole car, no mods this time around) Link to comment Share on other sites More sharing options...
BoozeRS05 Posted February 26, 2019 Share Posted February 26, 2019 (edited) You can be very hard on your brakes, just don't hold them at a stop afterwards. Warping and deposits can feel very similar is my understanding. For instance, whenever I get a "warped" feeling in the brakes I'll give them a couple really hard stops (safely), but not to a complete stop, and then I find a route where I'm not using them much or at all until completely cooled. Also as a trick, during daily driving if I think my brakes are building up heat I won't stop on them fully. I'll give room and creep towards lights/traffic/etc without ever fully stopping. Once you're ready for new rotors - get Centric Premiums with the painted hubs or an equivalent at any auto parts store (painted hubs!). Once you're ready for new pads - get something good (commonly Hawk HPS pads in the past). The main components are fine, but good pads are key. Edited February 26, 2019 by BoozeRS05 EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
gathermewool Posted February 26, 2019 Share Posted February 26, 2019 You can be very hard on your brakes, just don't hold them at a stop afterwards. Warping and deposits can feel very similar is my understanding. For instance, whenever I get a "warped" feeling in the brakes I'll give them a couple really hard stops (safely), but not to a complete stop, and then I find a route where I'm not using them much or at all until completely cooled. Also as a trick, during daily driving if I think my brakes are building up heat I won't stop on them fully. I'll give room and creep towards lights/traffic/etc without ever fully stopping. Once you're ready for new rotors - get Centric Premiums with the painted hubs or an equivalent at any auto parts store (painted hubs!). Once you're ready for new pads - get something good (commonly Hawk HPS pads in the past). The main components are fine, but good pads are key. +1 In cleaning the pads, I've noticed that it sometimes takes multiple heavy stops (not to full stop) to sufficiently clear the rotor of deposits. The next time your rotors "warp", Google "bedding in brakes" and follow those instructions. '15 FB25 Magnatec 0W-20 + FU filter (70,517 miles) RSB, Fr. Strut Bar, Tint, STI BBS, LED er'where Link to comment Share on other sites More sharing options...
Grnlantern1 Posted February 27, 2019 Share Posted February 27, 2019 Hey folks, I have approx 44k miles on the '15 legacy 3.6 and the brakes feel warped again. The dealer had 'turned' them at @36k miles as they did have a warp to them. So the question, have any of you upgraded rotors/pads or just stick with oem? My prior car was an 02 wrx with several mods, some of which were brakes, that car stopped dreat. ThanksI upgraded to the Sti Brakes n Rotors and had no issues.. Depends on your budget but you can find the Calipers pretty cheap then get some DBA 4000 Rotors.. Sent from my SM-G965U using Tapatalk Link to comment Share on other sites More sharing options...
ncted Posted February 27, 2019 Share Posted February 27, 2019 Hey folks, I have approx 44k miles on the '15 legacy 3.6 and the brakes feel warped again. The dealer had 'turned' them at @36k miles as they did have a warp to them. So the question, have any of you upgraded rotors/pads or just stick with oem? My prior car was an 02 wrx with several mods, some of which were brakes, that car stopped dreat. Thanks In addition to the DBA 4000, I would recommend these, assuming you just need fronts: https://www.knsbrakes.com/c/car-series/2938_2015+Subaru+Legacy+3.6R+Limited/815_KNS+Brake+Rotor+-+Single+Rotor I put these on my wife's Forester XT, and the warping stopped. Link to comment Share on other sites More sharing options...
bowenx Posted March 3, 2019 Author Share Posted March 3, 2019 Sorry for delayed reply... Thanks for your comments. Not sure on path to take just yet. I will need to see what they come back with the next time i bring it in. Link to comment Share on other sites More sharing options...
bowenx Posted April 9, 2019 Author Share Posted April 9, 2019 (edited) In addition to the DBA 4000, I would recommend these, assuming you just need fronts: https://www.knsbrakes.com/c/car-series/2938_2015+Subaru+Legacy+3.6R+Limited/815_KNS+Brake+Rotor+-+Single+Rotor I put these on my wife's Forester XT, and the warping stopped. Dumb question, which ones did you select? It doesnt show a forester or legacy as an option? Assuming they would be compatible with wrx rotors? Thanks Edit:i see it says legacy in upper right and in url. And ability to select via home page. Edited April 9, 2019 by bowenx i am a dope Link to comment Share on other sites More sharing options...
airken888 Posted April 9, 2019 Share Posted April 9, 2019 Are you using stock rotors and pads? Link to comment Share on other sites More sharing options...
bowenx Posted April 9, 2019 Author Share Posted April 9, 2019 Are you using stock rotors and pads? Currently, yes I am. Car has approx 46k miles on it, bone stock except the 20mm RSB that i installed this weekend. Link to comment Share on other sites More sharing options...
airken888 Posted April 10, 2019 Share Posted April 10, 2019 I'm on Centric rotors and stock pads for the last 5 years and haven't had any issues so far. Link to comment Share on other sites More sharing options...
whitetiger Posted April 10, 2019 Share Posted April 10, 2019 nothing wrong with a pad upgrade if you want. going with a street performance pad will generally be all that you will ever need. as for rotors, nothing more that a set of centric blanks are necessary. Link to comment Share on other sites More sharing options...
BoozeRS05 Posted April 10, 2019 Share Posted April 10, 2019 Fully agreed. Get a decent performance pad, but basic rotors are fine (W/ PAINTED HUBS). EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
