bigman100 Posted February 25, 2019 Share Posted February 25, 2019 (edited) I have looked for weeks to find a simple answer to what i think is a simple question, which is, will the 2.5 from an 04 Impreza Outback Sport auto be a direct swap for an 05 Legacy L auto. If it isnt a direct swap, can i use the 04 long block, and the 05 intake and sensors, or do i need to also change over other components? Im not sure if it matters or not, but, the 6th digit in the vin on both cars is a 6. Edited February 25, 2019 by bigman100 Link to comment Share on other sites More sharing options...
Osei Posted February 26, 2019 Share Posted February 26, 2019 AFAIK you only have to change intake and sensors, especially the crank sprocket. The 05 is DBW. Also check to see if the driver's side cam sprocket is the same. Am essentially doing the same with an 01 block, though in my case I am changing the heads as the 05 block is seized, while the 01 has bent valves. O. Link to comment Share on other sites More sharing options...
