AwaySubaruThrow Posted February 22, 2019 Share Posted February 22, 2019 I have a p0106 error code. "Manifold absolute pressure / Barometric Pressure Sensor Range/ Performance" I checked the Mass Air Flow Sensor, and it does not look dirty to me https://imgur.com/XzmB2Cl https://imgur.com/Xf6glUt But I'll get some Mass airflow sensor cleaner and try to clean it out. I did notice that the housing of the Mass air flow sensor and air filter is damaged, would that throw anything off? https://i.imgur.com/8zCDoxE.jpg https://i.imgur.com/iLaMA28.jpg Also, where is the MAP sensor? I found this thread detailing pictures https://legacygt.com/forums/showthread.php/95-legacy-2-2-map-sensor-location-255886.html But I can't find it on my car. Here are pictures of my engine https://i.imgur.com/q8Rw2r6.jpg https://i.imgur.com/gIs5sFq.jpg https://i.imgur.com/RPhB4WCr.jpg https://i.imgur.com/UWVwpPo.jpg https://i.imgur.com/AmfbvTh.jpg https://i.imgur.com/3jHGXEh.jpg https://i.imgur.com/J2oEgw8.jpg https://i.imgur.com/b13oUo5.jpg https://i.imgur.com/FfLmsMX.jpg https://i.imgur.com/eeFNOxs.jpg https://i.imgur.com/2pHjBA2.jpg https://i.imgur.com/CWHN9xJ.jpg https://i.imgur.com/ETjLOXG.jpg https://i.imgur.com/f8bdBJ8.jpg https://i.imgur.com/tcw4W90.jpg https://i.imgur.com/9JB8RfW.jpg https://i.imgur.com/tYoknc2.jpg https://i.imgur.com/6Eyv0NW.jpg https://i.imgur.com/OXlWmNg.jpg https://i.imgur.com/GO5YqvA.jpg https://i.imgur.com/R8jk4Kd.jpg https://i.imgur.com/XmTvqxI.jpg https://i.imgur.com/9qu8NUE.jpg https://i.imgur.com/Ncfbje9.jpg https://i.imgur.com/RbrlhQY.jpg https://i.imgur.com/O7tNLnI.jpg https://i.imgur.com/xfGL7ef.jpg Link to comment Share on other sites More sharing options...
Brighton96 Posted February 23, 2019 Share Posted February 23, 2019 uuhhh the 2.2 doesn't use a MAP sensor, only MAF Link to comment Share on other sites More sharing options...
Notorious Posted February 23, 2019 Share Posted February 23, 2019 Top left of this photo coming off the throttle body looks like your MAP sensor. Link to comment Share on other sites More sharing options...
Brighton96 Posted February 23, 2019 Share Posted February 23, 2019 That's the TPS sensor. I have a 96 and I know mine doesn't have a map sensor unless one of the vacuum lines goes to one of the unidentified solenoids which are a map sensor and I don't know it. Link to comment Share on other sites More sharing options...
doublechaz Posted February 23, 2019 Share Posted February 23, 2019 My 2.2 definitely does not have a MAP. I thought only the turbos had both, but I'm not a Subaru expert so much as I am devoted to my car. Does the ECU in question come originally from the car in question, or has there been some swapping about? Link to comment Share on other sites More sharing options...
Brighton96 Posted February 24, 2019 Share Posted February 24, 2019 It's really hard to say whether its a connection issue or a sensor issue but what I'd do if I were you is, I'd go to the auto parts store, buy a can of quick dry electrical cleaner and then progressively disconnect and spray out every single connector you can find under the hood, obviously do this with the battery disconnected. Which will also clear the code, then once you are done, reconnect everything and see if the code comes back. $6 and 30 mins for a quick way to rule out a faulty connection. Link to comment Share on other sites More sharing options...
