Mikekuni Posted February 11, 2019 Share Posted February 11, 2019 Battery died, installed a new one, and now the doors won't lock and the windows don't roll down. Help please? Link to comment Share on other sites More sharing options...
Notorious Posted February 11, 2019 Share Posted February 11, 2019 Try resetting the ECU. Disconnect the ground terminal, get back in the car and stomp the brakes a few times and play with the window lock button and switches, connect the ground terminal again. Leave the key in the accessory position for at least 20 seconds before starting it up. It might stall out a few times on the first drive. Link to comment Share on other sites More sharing options...
Mikekuni Posted February 12, 2019 Author Share Posted February 12, 2019 Reset but still doesn't work. Any other thoughts? Link to comment Share on other sites More sharing options...
relative4 Posted February 12, 2019 Share Posted February 12, 2019 Blown fuse Link to comment Share on other sites More sharing options...
apexi Posted February 12, 2019 Share Posted February 12, 2019 Check these fuses Link to comment Share on other sites More sharing options...
Rhitter Posted February 13, 2019 Share Posted February 13, 2019 same thing happened to me. It was just a blown fuse. There are / should be spares in your engine bay. My OBXT build Link to comment Share on other sites More sharing options...
Homedepotmade Posted February 15, 2019 Share Posted February 15, 2019 I second blown fuse but I had a random issue with my 08 Legacy keys having a delay or being unresponsive after I replaced my car battery. I did the idle relearn and it seem to fix everything. Link to comment Share on other sites More sharing options...
Mikekuni Posted February 17, 2019 Author Share Posted February 17, 2019 Checked those 3 fuses but all were good. Any other fuses? Link to comment Share on other sites More sharing options...
Mikekuni Posted February 17, 2019 Author Share Posted February 17, 2019 I also reset the ecu. No luck still not working. Link to comment Share on other sites More sharing options...
apexi Posted February 17, 2019 Share Posted February 17, 2019 For all door locks not working, the factory service manual says to inspect fuses 3 and 7 inside the car. Part of me wonders about the driver side window switch, since I think everything goes through that. I wouldn't just replace it without knowing it's bad though. Does the passenger window work if you use the passenger switch, and what about the rear windows using the switches in the rear doors? When you say the car doesn't lock, is that using the key fob, and the driver door/window switch? For the windows not working, the factory service manual says this. Symptom All power windows do not operate. Repair order (1) Fuse (SBF-4) (2) Power window circuit breaker (looks like it's somewhere behind the gauge cluster, or in front of your knees when driving?) (3) Power window relay (4) Wiring harness (5) Body integrated unit If you only press the window switches down part way, not using the auto up/down feature if the car has that, will they work then? Or do you get nothing no matter how you hold the switches? Link to comment Share on other sites More sharing options...
Mikekuni Posted February 17, 2019 Author Share Posted February 17, 2019 All windows don't work even when using the passenger switch. Screen when I don't use the auto roll down. The fob doesn't lock the car. Neither does the lock switch on the door. I'll try to look at the other things tomorrow.thanks! Link to comment Share on other sites More sharing options...
Road_dog Posted February 17, 2019 Share Posted February 17, 2019 My '05 LGT used to stop controlling the windows on extremely hot days. It was intermittent and then would go back to normal once things cooled off. I always suspected it could be the contacts on the driver side controller. Might be worth pulling that driver side controller and cleaning up the contacts. This still doesn't explain why the keyfob won't lock the doors. Could be fuses or the keyfob battery. Link to comment Share on other sites More sharing options...
Mikekuni Posted February 18, 2019 Author Share Posted February 18, 2019 My '05 LGT used to stop controlling the windows on extremely hot days. It was intermittent and then would go back to normal once things cooled off. I always suspected it could be the contacts on the driver side controller. Might be worth pulling that driver side controller and cleaning up the contacts. This still doesn't explain why the keyfob won't lock the doors. Could be fuses or the keyfob battery. Is it the controller on the door? Link to comment Share on other sites More sharing options...
Mikekuni Posted February 18, 2019 Author Share Posted February 18, 2019 ...SO STUPID... So I checked all the fuses in the engine compartment with a fluke, all was good. Also looked at then visually... But my eyes aren't that good anymore, but everything looks good. Turns out the fuse for sbf4 was broken but when I would ohm it, it shows good.... So thank you everyone! Link to comment Share on other sites More sharing options...
