Scoobiidoo Posted February 11, 2019 Share Posted February 11, 2019 Sometimes when I fire up the car, the engine just feels like it is raring to go with lively throttle response. Other times it just drags and takes a bit more throttle pushing to start responding. :confused: Link to comment Share on other sites More sharing options...
iHeartsubaru Posted February 11, 2019 Share Posted February 11, 2019 I feel the same way sometimes. I wonder if it’s the DBW... Link to comment Share on other sites More sharing options...
bigBADbenny Posted February 11, 2019 Share Posted February 11, 2019 Have you logged and lv’d the car? Romraider or Btssm? Link to comment Share on other sites More sharing options...
mondtster Posted February 11, 2019 Share Posted February 11, 2019 Consistency isn’t the hallmark of factory calibrations but there are things you can do to help make them perform the same all the time. If it is that noticeable however, I’d be looking to find why. My suspicion is that something isn’t right. It may take a fair amount of logging and driving to establish a pattern and figure out what is going on, but that is part of tuning. Link to comment Share on other sites More sharing options...
Max Capacity Posted February 11, 2019 Share Posted February 11, 2019 Have you cleaned the MAF sensor, once a year if not twice a year ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Scoobiidoo Posted February 12, 2019 Author Share Posted February 12, 2019 First of all, I have only owned this OBXT for a month. And yes I have cleaned the MAF already. Between having erratic AVCS solenoids(replaced and all is good) and hunting for vacuum leaks, I have replaced all the fluids/oils and some vacuum hoses. The car is still not hitting target boost and vacuum leaks are still there. Just received the Tactrix port and still learning about the EcuFlash and Romraider. What parameters should I log? How do I attach my Stage 1 base map here? Link to comment Share on other sites More sharing options...
relative4 Posted February 12, 2019 Share Posted February 12, 2019 Well, that is a big fat vacuum leak. Smoke test and fix. Link to comment Share on other sites More sharing options...
Scoobiidoo Posted February 12, 2019 Author Share Posted February 12, 2019 Well, that is a big fat vacuum leak. Smoke test and fix. I am starting to think it is gasket leaks from the intake manifold, TB, TGV or cam sensor. The car has 107k miles and lives in the desert most of its life Link to comment Share on other sites More sharing options...
mondtster Posted February 12, 2019 Share Posted February 12, 2019 Between having erratic AVCS solenoids(replaced and all is good) Are you sure it’s good? Because in the back of my mind erratic cam timing was one thing I was thinking of when I wrote my first post. I didn’t even know you had problems previously. First thing I’d record is desired and actual cam timing. And I’d be looking for a vacuum leak. It’s not off the scale yet but getting close. Get this kind of stuff figured out/fixed before messing with the ECU too much and masking bigger problems... Link to comment Share on other sites More sharing options...
Scoobiidoo Posted February 12, 2019 Author Share Posted February 12, 2019 Are you sure it’s good? Because in the back of my mind erratic cam timing was one thing I was thinking of when I wrote my first post. I didn’t even know you had problems previously. First thing I’d record is desired and actual cam timing. And I’d be looking for a vacuum leak. It’s not off the scale yet but getting close. Get this kind of stuff figured out/fixed before messing with the ECU too much and masking bigger problems... It was the left AVCS. It was always laggy. I replaced both for good measure and now they are both in sync and on target. My goal is to slowly replace all aging sensors, gaskets and hoses. O2 sensor is on the list. One by one I will get to the bottom of the vacuum leak Link to comment Share on other sites More sharing options...
