Mikekuni Posted February 9, 2019 Share Posted February 9, 2019 So as it says in the title. I had to replace the turbo inlet, much harder than I thought was going to be, and I don't remember how to hook up the vacuum lines. Does anyone have like a picture or diagram? Much appreciated! Link to comment Share on other sites More sharing options...
apexi Posted February 9, 2019 Share Posted February 9, 2019 Not owning a turbo, I don't know which lines you need, but hope these links help. Link #1 is probably the one you need. https://legacygt.com/forums/showpost.php?p=5466070&postcount=26 https://legacygt.com/forums/showthread.php/2005-2006-lgt-colored-vacuum-routing-diagram-143225.html Link to comment Share on other sites More sharing options...
Max Capacity Posted February 9, 2019 Share Posted February 9, 2019 There is a sticky in one of the forums, https://legacygt.com/forums/showthread.php/2005-2006-lgt-colored-vacuum-routing-diagram-143225.html 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
