Ludez Posted February 3, 2019 Share Posted February 3, 2019 So my bl5 has developed a whining/metallic sounding noise above 40 mph, and gets louder with speed. I thought possibly a wheel bearing? Or both wheel bearings? Link to comment Share on other sites More sharing options...
devobuzz Posted February 4, 2019 Share Posted February 4, 2019 Turn the wheel when you hear it. It will change pitch if it's a wheel bearing. You should be able if it is front or back. Link to comment Share on other sites More sharing options...
Ludez Posted February 4, 2019 Author Share Posted February 4, 2019 Turn the wheel when you hear it. It will change pitch if it's a wheel bearing. You should be able if it is front or back.Ok cheers I'll try that now Link to comment Share on other sites More sharing options...
Ludez Posted February 4, 2019 Author Share Posted February 4, 2019 Turn the wheel when you hear it. It will change pitch if it's a wheel bearing. You should be able if it is front or back.Ok would just drove it and tested around my block to see if the noise changed and it didn't change at all. Link to comment Share on other sites More sharing options...
Ludez Posted February 6, 2019 Author Share Posted February 6, 2019 Any ideas? Link to comment Share on other sites More sharing options...
Max Capacity Posted February 6, 2019 Share Posted February 6, 2019 See if you can find a large store in a strip mall that you can drive next to with your window down and see if you can hear the noise, may be it will help you pin point the area making the noise. 40mph may be tough. The other way is listen on a flyover or high speed exit ramp on the highway. Turn off the radio and see if you can hear anything as you change directions. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Ludez Posted February 6, 2019 Author Share Posted February 6, 2019 See if you can find a large store in a strip mall that you can drive next to with your window down and see if you can hear the noise, may be it will help you pin point the area making the noise. 40mph may be tough. The other way is listen on a flyover or high speed exit ramp on the highway. Turn off the radio and see if you can hear anything as you change directions.It's definitely front of the car, around the wheels area. Just unsure what though Link to comment Share on other sites More sharing options...
