fizzlefish Posted January 27, 2019 Share Posted January 27, 2019 So i am currently mating the motor to the trans but having a hell of a time lining it up. When i pulled it the TC was attached to motor so when putting it back in i attached it to the flex plate. Now im thinking i should have put it in the bell housing first. Which way is the best way to do it? Thanks. Link to comment Share on other sites More sharing options...
moral hazard Posted January 27, 2019 Share Posted January 27, 2019 Yeah the flex plate should be bolted to the engine first. Other than that, maybe get someone to assist during this part. It was very tricky for me also. Link to comment Share on other sites More sharing options...
Infosecdad Posted January 27, 2019 Share Posted January 27, 2019 Go find the “vacation pics” aka Service Manual for reinstalling the torque converter. Not sure about Subaru, but 30yrs ago I screwed up a Ford automatic by trying to attach the torque converter to the flex plate and installing it that way. There was a procedure to fit it to the tranny, then bolt to the flexplate through the access hole after mating the tranny to the engine. Link to comment Share on other sites More sharing options...
08SpecB_DE Posted January 27, 2019 Share Posted January 27, 2019 Go find the “vacation pics” aka Service Manual for reinstalling the torque converter. Not sure about Subaru, but 30yrs ago I screwed up a Ford automatic by trying to attach the torque converter to the flex plate and installing it that way. There was a procedure to fit it to the tranny, then bolt to the flexplate through the access hole after mating the tranny to the engine. This is the correct way. Dont forget a little locktite on the TC bolts. Link to comment Share on other sites More sharing options...
whitexc Posted January 28, 2019 Share Posted January 28, 2019 Yes, you can damage the front seal and or bushing trying to put it together the way you are. Good call on the BLUE locktite on the TC bolts. Link to comment Share on other sites More sharing options...
fizzlefish Posted January 28, 2019 Author Share Posted January 28, 2019 Thanks guys. I took the motor back out and did it the right way. Link to comment Share on other sites More sharing options...
