mtsubi Posted January 25, 2019 Share Posted January 25, 2019 (edited) I have a 1994 Subaru Legacy with the turbo engine. a Couple weeks ago the car would not start. i stepped away from it till i had time to work on it now every time i turn the key to the run position multiple relays click off and on. the relays i have found that do it are the fuel pump relay the electric fan relay and looks like a relay that is connected to the injectors on the passenger side. What could be causing this issue. this is my daily driver so hoping to get ideas from you guys and gals, thank you Edited January 25, 2019 by mtsubi Link to comment Share on other sites More sharing options...
Brighton96 Posted January 25, 2019 Share Posted January 25, 2019 Low battery voltage or poor connection from battery to starter will result in multiple clicks from the starter, whereas a single click from the starter would result in a bad starter solenoid. No clicks at all could be any of those as well as a bad relay. Link to comment Share on other sites More sharing options...
mtsubi Posted January 25, 2019 Author Share Posted January 25, 2019 so could a bad battery cause the relays to click on and off. all i do is turn the key to the run position and my fuel pump and electric fans will turn on and off and can hear the relays click when they go on and off . not sure if this makes sense lol. the starter works fine but it seems like there is something going on in the electrical. Link to comment Share on other sites More sharing options...
Brighton96 Posted January 26, 2019 Share Posted January 26, 2019 There are a few relays that are identical but are assigned to different tasks, so for example, the fuel pump and starter are the same relays (I'm not sure if they actually are) so see if anything changes when you swap them. Link to comment Share on other sites More sharing options...
jghoodgt Posted October 5, 2020 Share Posted October 5, 2020 2009 spec b, just rebuilt the engine and went to power up for the first time. Seems like every relay is freaking out. Fans off and on, a/c clutch pulling in and out. Ecbs engaging. Basically every single electronic in the car is turning off and on. You ever figure out what was up with yours? Link to comment Share on other sites More sharing options...
doublechaz Posted October 6, 2020 Share Posted October 6, 2020 Sounds like the green diagnostic connectors are connected. They should not be for normal use. When connected lots of relays turn on and off so you can listen to them operating. Link to comment Share on other sites More sharing options...
jghoodgt Posted October 6, 2020 Share Posted October 6, 2020 Hahaha. That’s what that was? Running gauge wires through the firewall and saw them disconnected. Thought maybe that’s why my hazards didn’t work. Plugged them in. Thank you, thank you, thank you. Link to comment Share on other sites More sharing options...
doublechaz Posted October 6, 2020 Share Posted October 6, 2020 Glad it was that easy. And thanks for reporting back. Link to comment Share on other sites More sharing options...
jghoodgt Posted October 7, 2020 Share Posted October 7, 2020 Tried it last night. Everything’s fine. Just waiting on a fuel pump and hopefully this piece runs without leaking. Link to comment Share on other sites More sharing options...
