MySubieII Posted January 22, 2019 Share Posted January 22, 2019 Anyone ever try to retro for heated steering wheel? Are there kits? Thanks. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
KartRacerBoy Posted January 22, 2019 Share Posted January 22, 2019 gloves Link to comment Share on other sites More sharing options...
Golferdude1087 Posted January 22, 2019 Share Posted January 22, 2019 (edited) I am looking into this. There are a whole host of problems associated with this and honestly, its probably not possible: Easy pieces 1) the steering wheel circuit is self contained, aside from the connected fuse Hard pieces 1) The steering wheel airbag is different (but is apparently plug and play) 2) The steering wheel buttons are radically different in all facets, you will need to know how to adjust the wiring to work correctly 3) The steering wheel has paddle shifters..not sure if it can be done with them disconnected, or even removed. In truth. to do this you are looking at around $700 just in parts..if its even possible... Edited January 23, 2019 by Golferdude1087 Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted January 23, 2019 Share Posted January 23, 2019 even when it is -30f my steering wheel does not remain cold for long...and +1 to gloves you can do it but you are going to need things like a clock spring in addition to the heated wheel assembly and you will most likely going to have to add to the wire harness Link to comment Share on other sites More sharing options...
DrD123 Posted January 25, 2019 Share Posted January 25, 2019 the 17+ outback touring has a heated steering wheel - no idea if a retrofit is possible, though Link to comment Share on other sites More sharing options...
Golferdude1087 Posted January 25, 2019 Share Posted January 25, 2019 the 17+ outback touring has a heated steering wheel - no idea if a retrofit is possible, though Thats where my explanation came from. The outback, ascent, and foz all have the same wheel (which is different from ours). There is virtually no way to know unless someone grabs a cheap wheel and starts playing around. Link to comment Share on other sites More sharing options...
DrD123 Posted January 25, 2019 Share Posted January 25, 2019 there are all sorts of heated steering wheel covers available - just do a quick search on Amazon. Link to comment Share on other sites More sharing options...
