tfrasca Posted January 13, 2019 Share Posted January 13, 2019 I have a pretty good amount of water collecting under the rubber/foam insulation under the rear seat bottom. Any common causes for that? I've done a search and I'm not turning up anything. Thanks! Link to comment Share on other sites More sharing options...
compsurge Posted January 13, 2019 Share Posted January 13, 2019 Spray the car with a hose and see if you can isolate where it is leaking. Does it collect water after driving or after sitting? Check trim seals for cracking. Link to comment Share on other sites More sharing options...
RumbleRumble Posted January 14, 2019 Share Posted January 14, 2019 Try unclogging the drain ports for your sunroof. https://www.subaruoutback.org/forums/99-do-yourself-illustrated-guides/8005-clean-your-sunroof-drain-hose.html Link to comment Share on other sites More sharing options...
tfrasca Posted January 15, 2019 Author Share Posted January 15, 2019 Spray the car with a hose and see if you can isolate where it is leaking. Does it collect water after driving or after sitting? Check trim seals for cracking. Try unclogging the drain ports for your sunroof. https://www.subaruoutback.org/forums/99-do-yourself-illustrated-guides/8005-clean-your-sunroof-drain-hose.html Thanks guys. I cleaned up all the "water". Upon closer inspection, it may have been something oil-based. It was reddish-orange in color, but I assumed that was from all the redwood needles and dirt that's jammed in every crevice of this car. Anyway, I cleaned it all out, and after two solid days of rain, no water is collecting there. The bummer is that the foam insulating mat under the rear seat was trashed, so I guess I'll be heading to the junkyard to find a replacement soon. For now, I'll move on to the next thing - rear trailing arm bushings to get rid of the annoying squeak. Link to comment Share on other sites More sharing options...
