06SubLegTx Posted January 12, 2019 Share Posted January 12, 2019 Hello, can anyone tell me where the Turn Signal Relay is located? Thanks for the Help. Link to comment Share on other sites More sharing options...
apexi Posted January 12, 2019 Share Posted January 12, 2019 I'm reluctant to reply because I'm not positive, but It looks like it's post #89 in the link below.. https://legacygt.com/forums/showthread.php/gauging-interests-bp5-led-tail-light-125615p6.html?t=125615&page=6 https://legacygt.com/forums/showpost.php?p=2756802&postcount=89 *direct link to 89 I tried looking in the fsm and on parts.subaru.com, and didn't really find anything.. It's hard to read, but it looks like the oem denso relay in post #89 is 86111AG010, and has been replaced by 86111AG011. parts.subaru.com seems to sell that as part of the whole relay holder assembly? and I don't see the relay listed in this list.. https://parts.subaru.com/a/Subaru_2006_Legacy-Limited-25L-4AT-4WD/_52016_6029192/RELAY-CHART/B13-899-01.html Link to comment Share on other sites More sharing options...
rhino6303 Posted January 12, 2019 Share Posted January 12, 2019 The relay is attached to the top of a large plastic relay panel. It is located directly next to the fuse box under the driver side dash. If you pull the undercover and trim, you'll see a black plastic part full of blue relays. This unclips from the left and the turn signal relay is a beige relay attached to the top. Link to comment Share on other sites More sharing options...
jrho Posted January 12, 2019 Share Posted January 12, 2019 ^^^ this is correct. Good luck getting the tab on the relay to cooperate. When I was swapping mine out for the Smart Tap relay, I ended up breaking off the tab in frustrating haha Link to comment Share on other sites More sharing options...
