LinuxJon Posted January 11, 2019 Share Posted January 11, 2019 Really puzzled and concerned. I'm taking a planned trip the mountians this weekend and don't want to get stuck. My 2017 2.5 died this morning right after turning over. Idled for 1-2 seconds, RPMs go to 0, check engine, oil light, ect all come on. I try starting it 2-3 more times with the same results. Let it sit for a second, turn it over, and it stayed on this time. Plenty of gas- like a 1/2 tank and I drove it all the way to work. At lunch, car started fine. Leaving to head back to work from lunch, it did the start/die thing a couple more times, then was fine. Seems like it's its running more than 3 seconds, it's fine. I do have a lot (55k) miles on my 2017. Really worried b/c in a couple months the warranty will be up. Any ideas what this might be? Link to comment Share on other sites More sharing options...
ehsnils Posted January 12, 2019 Share Posted January 12, 2019 It's hard to tell, but fuel pump is one idea. But since it's under warranty you should report it to the dealer and have them take a look at it. That way you have it recorded. Link to comment Share on other sites More sharing options...
moral hazard Posted January 12, 2019 Share Posted January 12, 2019 I would check vacuum lines first because it can be pretty easy to DIY. Also I suggest getting the Torque app on android and an obd2 adapter so you can read the sensors. Check what the fuel trim looks like, has the ecu learned to add or remove 15% fuel ? Give the MAF sensor a clean also. Link to comment Share on other sites More sharing options...
iyalla Posted January 12, 2019 Share Posted January 12, 2019 Unplug the MAF sensor and see if it holds idle. It will run a little rough but if it does hold idle, then clean the MAF sensor. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted January 14, 2019 Share Posted January 14, 2019 data log it. Engine stalling immediately after start up is OPEN LOOP operation, it takes about 30 seconds for the engine enter closed loop... Things that the engine needs to start besides fuel air and spark crank position sensor MAF also what does the computer think your throttle is at after start? Link to comment Share on other sites More sharing options...
ammcinnis Posted January 14, 2019 Share Posted January 14, 2019 (edited) Engine stalling immediately after start up is OPEN LOOP operation, it takes about 30 seconds for the engine enter closed loop... I've checked our 2015 Legacy 2.5 and 2016 Outback 2.5, and both consistently enter closed-loop mode within 8 seconds of a cold start. That's the primary reason why modern engines have electrically-heated O2 sensors in their exhaust systems. Edited January 14, 2019 by ammcinnis "If you don't know where you're going, any road will take you there." ~ The Cheshire Cat (Alice in Wonderland) Link to comment Share on other sites More sharing options...
